FMIC AMS v. ETS v. Perrin (Discussion)
I am currently looking for a intercooler for my EVO X. Right now I have the COBB Hardpipe Kit, Cobb Turbo Inlet, COBB SF Intake coming in for the car.
I am looking to upgrade to a larger intercooler for mostly street driving and some track/autoX events.
The car will have the stock turbo in it for the next 2 years minimum. Therefore I am looking for something that has the smallest pressure drop.
If you have any knowledge why any other brand is better than the current brands I listed, please post your reply. *** "xxxxxxx" FTW *** is NOT good enough.
***Please do not post pricing or smack talk any company, this is thread is a discussion of the pro's and cons of each setup***
AMS (CAST END TANKS)
12.4" tall, 20" wide (32" with end tanks and bracket) and 3.625" thick
1250 cfm flow and only 1 psi pressure drop at 650 whp
Bar & Plate Core
VOLUME: 892.8
ETS (SHEET METAL WELDED END TANKS) 3.5" or 4.0"
20x12x3.5 Bar & Plate Core - 750hp Direct Replacement
20x12x4.0 Bar & Plate Core - 820hp Direct Replacement
VOLUME 3.5" 840
VOLUME 4.0" 960
PERRIN (CAST END TANKS)
PERRIN 20.75" x 12.375" x 3.625" = 930 cu-in Ambient cu-in 256cu-in
Bar & Plate Core
VOLUME: 928.5
AGP (Cast End Tanks)
20x13x3.5 bar and plate core
VOLUME: 910
Bar & Plate Core
Bar & Plate Core
VOLUME: 892.8
VOLUME 3.5" 840
VOLUME 4.0" 960
Bar & Plate Core
VOLUME: 928.5
VOLUME: 910
Bar & Plate Core
18 might be a better option though, design is key. When I owned an SRT-4 one of the best Intercoolers was much smaller(Old Evo 8 shape design) in width compared to all the rest of the wider, "huge" style intercoolers and it outperformed them all.
Has it been shown for IC's to be worthy on the stocker? or at a certain power level?
what about AGP?? i have heard good things about them.. something else to consider.
are you planning on upgrading the turbo in the future? if so, i say a larger intercooler would be the best thing. but thats just my .02
I'd go with the perrin although the rest are as good , the perrin is a better quality IC hence the higher price tag, and @ empirepb210 i think if you asked them to stencil it they would I've seen a lot of inter coolers with perrin on the front although ti prefer my IC'S anodized.
personally i have the AGP IC - cast, 3.5" core for $500 shipped from the group buy. price for value is hard to beat at that price point.
i doubt the perrin's "better quality" has anything to do with price - it all comes down to sheet metal or cast, and thickness/efficiency of the core. to that extent, i see the cast ICs are better over sheet metal (heavier but better collector), and core size, well, it depends on your needs. for most of us, a 3.5" thick core is more than sufficient.
Wow, that's awesome.
I have a wide end tank ETS 4" core for my IX and it very well made and fit as expected. I have always heard that ETS parts fit very well and in my experience of a few parts, that is very true.
The issue of the "best FMIC" has been discussed extensively here: https://www.evolutionm.net/forums/ev...rcooler-3.html and elsewhere. To me there are some critical variables that should be considered:
(1) pressure drop (as mentioned by Clipse3GT) but at a specified airflow
(2) temperature drop also at a specified flow rate
(3) frontal area relative to same for vehicle (there is only so much area available for direct exchange on any vehicle)
(4) ease of installation (do you have to hack into the the bumper assembly to install; 4" will be more difficult than a 3" wide)
(5) size of FMIC and its influence on engine's radiator efficiency
(6) cost.
The second item is especially important since the X has high temperature inputs as discusssed by Perrin earlier (see their website) due to proximity of the X's exhaust manifold. In an experimental world, it would be really informative to have temp sensors in and out of FMIC for various loads UNDER ROAD CONDITIONS for each vendors core. By so doing, in conjunction with the other items/variables listed above, our decision making would be rather trivial. Unfortunately such testing is unlikely so we will continue to be confused and uncertain when it comes to choosing a FMIC.
I know this little discourse solves nothing but it clearly shows the direction we need to go in: relevant testing under real world conditions.
Later, Ken
(6) cost.
Later, Ken
