Crank Pulley
doesn't look like it. http://www.google.com/search?hl=en&q...xt&sa=N&tab=fw
You need to be extremely careful man. Thats the main crank bolt. It will be easy to break loose with a breaker bar, but it will not be so easy to put back on, because as you go to put it back on with 160ft/lbs its going to turn the rest of the crank, so you're gonna need something to hold your crank still. post this in in the proper section so you dont mess your car up. good luck.
_EVOlved_
151
Nov 26, 2006 06:04 PM
tx evo
34
Nov 26, 2003 12:58 PM
