Specialty X dual catback
Old Aug 13, 2009, 07:36 PM
  #31
mlomker's Avatar
Originally Posted by mlomker
I'm going to keep my car mostly stock but this exhaust seems like a must-have.
Questioning my sanity but decided to go TBE instead of CBE. The downpipe is awful expensive...the highest price that I've seen. I hope it is purty.
Old Aug 13, 2009, 10:52 PM
  #32
swingarm's Avatar
It's very purty.
Old Sep 23, 2010, 04:20 PM
  #33
AHAZZARD's Avatar
Ok , now that this thread has been open for over a year , i have some questions for those of you with this exhaust.
Does anyone have their car lowered on eibach pro kit with this exhaust? ( im worried about scrapping).
I have an AMS HFC right now and im wondering if I should get the resonated or non resonated Y pipe. IM worried if I dont get the resonator its going to be too loud , and if i do get the resonator its not going to be loud enough.
Please give your feed back
Old Sep 23, 2010, 04:44 PM
  #34
Mendo's Avatar
I've had it for a while.
I have the non resonated y pipe and its not bad at all. I will say I am running the stock cat so I'm not going to be as loud as you.
I am at stock height and haven't had any issue with it bottoming out. I do have the issue that it is scratching my driveshaft (I'm not the only one with this issue either). The section in the Y-pipe that goes underneath the shaft doesn't leave alot of clearance so every now and then u hear it scrape. Mine has cut through Someone mentioned that solid driveshaft bushings stopped this problem, not sure if its a "fix" though.
I would contact them and see if they have fixed this issue b4 u pull the trigger
Old Sep 24, 2010, 07:30 AM
  #35
AHAZZARD's Avatar
thanks for the info, i talked to a vender recently and he mentioned that i might have to twist the exhaust a little. so it sounds like they have not fixed the issue.
Old Nov 3, 2010, 07:15 AM
  #36
SiliconTek's Avatar
If they fixed it they didn't mention they did. Plausible deniability wins in this case.
joonvang
Jun 6, 2016 03:27 PM
CaptainCrunch
Northeast Region
Jun 2, 2016 03:07 PM
Weapon X
Jul 3, 2015 05:01 PM
bangpe13
14
Mar 6, 2015 05:49 PM
GNR
36
Jan 3, 2009 12:01 PM
Quick Reply: Specialty X dual catback
