Cobb/Perrin Turbo Inlet vs Nisei Turbo inlet
It's the placement of the blow off valve, we change the location of the blow off valve, and provide silicone to relocate the valve. The silicone intakes above look like they use the stock blow off valve location.
Good Luck! If you need any help, let me know!
Thanks,
Michael
Thanks,
Michael
But yes the Nisei intake pipe relocates the bov, and return hose to run underneath the intake, so you dont see the ugly hose. The intake pipe does not have the attachment for valve cover vent or boost contoller vent. The boost contoller vent tubes are vent to atmosphere (the stock unit vents back into the intake). Also there is no valve cover vent nipple. With the Nisei intake pipe, the valve cover vents to the atmosphere so not oil enters into the intake.
You dont need the Licp with the intake. You can run your stock LICP.
As such, with there stock configuration, the breather hose is used to draw air into the crankcase, not the other way round. As such, there should be no oil entering the intake (turbo inlet hose) b4 the turbo. Only the compressed air at the far end of the IM will see blow-by gas, just b4 the air is mixed with fuel.. did i missed anything?
EVO X Positive Crankcase Ventilation System
The positive crankcase ventilation (PCV) system prevents the escape of blow-by gases from inside the crankcase into the atmosphere. Fresh air is sent from the air cleaner into the crankcase through the breather hose to be mixed with the blow-by gas inside the crankcase. The blow-by gas inside the crankcase is drawn into the intake manifold through the PCV valve.
The PCV valve is designed to lift the plunger according to the intake manifold vacuum so as to regulate the flow of blow-by gas properly. In other words, the blow-by gas flow is regulated during low load engine operation to maintain engine stability, while the flow is increased during high load operation to improve the ventilation performance.
EEVOH
Northeast Region
Aug 27, 2015 07:02 PM
EEVOH
Aug 27, 2015 07:01 PM
Kracka
Evo X Dyno Results
295
Oct 3, 2012 03:03 PM
COBB Tuning
22
Sep 18, 2010 07:14 PM
