Intake...MAF...Tune?
So I'm thinking about getting the AMS Performance Intake soon and already have a tune on the bone stock X. I plan on getting a TBE and FMIC soon as well so I would like to wait for a tune until then.
The question...
So can the MAF compensate enough to keep the AFRs in check or if I should get it retuned?
I searched and all I could find was dyno results.
The question...
The question...
The question...
Your call, but your best bet is to check with whomever supplied your existing tune and see if there is enough wiggle room in the tuned AFR (If you were custom tuned with a cat there probably is as you need to run richer with a cat anyway) and timing.
I would think that since you are already running a "protune", your A/F ratio is already leaned out pretty good. Adding the aftermarket intake without another tune would most likey make you run too lean.
I personally would wait and get another protune once the rest of your other future mods are installed.
Mellon Racing
Southeast Region
27
Jun 24, 2011 04:59 PM
