buschur lower intercooler piping
will this fit the stock intercooler. cause on their website it says that it doest not work with the stock airbox. but they also say it bolts on to the stock intercooler. which is which? im a little confuse.
It sounds like you need an aftermarket short-ram type intake to replace the stock airbox. According to the description you gave, if you have that then the rest should bolt to the stock intercooler without problem.
im still learning about how turbo cars work. can you explain where the lower pipe connects to besides the intercooler? Also if you could explain the same with the upper pipe? thanks
The upper intercooler pipe (aka hot pipe) carries the hot, compressed air from the turbo to the intercooler, where the temperature is reduced. The lower intercooler pipe (cold pipe) then carries the cooled down air from the intercooler to the engine.
Go explore your engine bay and see what parts connect to each other, you'll learn a decent amount if you're not familiar with how everything works
The upper instercooler pipe goes into the intercooler at the top (duh) and the lower intercooler pipe goes out the bottom around the driver side to the engine throttle body.
Like he said just open up the hood and look around and it will make a lot more sense.
anthonypazsd
11
Jun 30, 2014 05:59 PM
opjohnsmith
Northwest Region
Mar 15, 2010 08:36 PM
