kelford stage 2 cams installed, car wont idle
ok this is what heppened, cams were installed (kelford stage 2) but the car wont idle so i figured it needs a tune
got a tune but still the same, we tried different maps but its no use!!
so i started snooping around the engine bay and found 3 huge boost leaks, even the intake wasnt hooked on right, so we fixed it, but the car still wont idle
it runs great when in motion and AFR is good, but when i take my foot of the gas (or when parked, same thing) the RPM dances between 0~800 RPM and then it dies
cars at the dealer now they are checking every thing and will get back to me tomorrow
any thoughts ???
any thoughts ???
Yeah what mods and who is tuning the idle portions of the timing and fuel maps? From what I recall I've heard people richen up idle to smooth out lumpy cams. Adjusting the timing can also effect how much vacuum it will pull at idle and too high or too low can cause drivability issues. I'll let someone that has already gone through this upgrade chime in with details!
here are the mods:
agency power 3" cat-back duel exhaust
O2 housing down pipe with O2 dump
ETS manifold
ETS 3" intercooler with 3" pipes
AEM cold air intake
FP red turbo
800cc injectors
walbro fuel pump
kelford stage 2 cams (270)
exedy clutch
perrin mbc
car being tuned by 4wheelslide
ETS manifold
AEM cold air intake
FP red turbo
800cc injectors
walbro fuel pump
exedy clutch
perrin mbc
Verify that injector scaling is 665 cc (richer side) or 680cc (leaner side) to get those 800 cc injectors dialed in. I picked 665 cc in order to compensate slightly for the AMS intake and it's still adding in 3-4% fuel on my LTFT (still slightly lean).
If the cams were installed a tooth off it could really make it hard to get the car to idle as well. What is vacuum at 1000 rpm if you artificially add in some throttle to keep it running?
I think he's stating that Stage 2 cams typically require upgraded valve springs. The OP doesn't have upgraded springs in his mod list.
The upgraded springs are certainly required for high RPM use to mitigate valve lash but I would think the stockers could handle idling...
I don't think most folks realise how "Big" the kelford stage 2 cams are. The best way to think about it is this in order of smallest to largest:
Kelford stage 1
Cosworth MX1
Kelford stage 2
I had to do a lot of mivec and fuel work with the MX1's. Needed a lot of fuel in the low rpm area and way less intake advance in the low load load rpm areas. Best vacuum I can get them to pull at idle (bumped to 850 or 900 iirc) right around 5.5 lbs vacuum.
First things first, you need to make sure the physical timing is correct and your not a tooth or more off in either direction. You can only add so much fuel at idle as the trims will compensate for any fuel you add or remove, unless of course you force the car to idle in open loop by setting the open loop load threshold to 10 at rpm points up to around 1200 - 1500, then you should be able to richen up the idle to 14.0:1 or so for starters. Also bump the timing a tad in the idle area's by 2 degrees or so.
Don't bother messing with the mivec on the exhaust side, from my logs it looked like the exhaust mivec setting did nothing up to a certain load and rpm, don't recall that load or rpm at the moment though.
Also, back out all the intake mivec advance (assuming you not still on the stock mivec maps) in the idle up to 1500 rpm or so areas. The goal is to reduce overlap at idle and very low load and rpm.
Kelford stage 1
Cosworth MX1
Kelford stage 2
