Which Turbo Kit to get?
Old Jul 11, 2009, 10:45 PM
  #46
flyguycfi's Avatar
I would really like to see someone with a 35R post up a dyno chart right about now. I'm very curious about comparing the two!
Old Jul 12, 2009, 06:00 PM
  #47
David Buschur's Avatar
I am saying I have never seen a 2 liter engine make 20 psi by 4,000 rpm. I personally measure 20 psi when I do all my testing and use that as my "spool up" comparison.
I have not tried to change springs on the car, I can't say if it is possible or not.
Old Jul 12, 2009, 06:14 PM
  #48
joshevo22's Avatar
I saw a dom2.5 on some site cant recall where but im guessing that would produce a decent amount of hp if the 2.0 is doing 450whp with all boltons etc.
Old Jul 12, 2009, 06:17 PM
  #49
RaysEvoX's Avatar
davidbuschur do you have any info/specs on the Dom 2.5?
Old Jul 12, 2009, 06:32 PM
  #50
Hiboost's Avatar
Indeed, for my testing of spoolup I usually do WOT at 2k in 4th gear and let off at the RPM it reaches 20 psi for my testing. You can compare MIVEC and other changes in the EvoScan logs pretty easily now that we have boost logging with the 3 bar MAP sensor.
I'll dig a little deeper to see if anyone has done the valve springs with the head on the car, thanks for being honest!
As for Dom 2.5 specs I think it's basically Ball bearing center section with a 47 lbs/min flow rating so actually slightly smaller than the Dom 2.0. A good search should yield the exact specs or contact Blouch.
Old Jul 13, 2009, 07:00 AM
  #51
JerseyEvox's Avatar
im going to get the fp red. look into it. very very nice
Old Jul 13, 2009, 08:07 AM
  #52
malymabl97's Avatar
FP Red is on sale @ FP site.
moey124
Aug 20, 2016 03:13 AM
xBoostx
Nov 10, 2015 09:02 AM
xBoostx
Nov 9, 2015 08:41 AM
Drizzy Drake
90
Oct 7, 2009 05:28 PM
incandescent
Dec 13, 2007 12:54 PM
Quick Reply: Which Turbo Kit to get?
