Question on Works console bushings
During install of the bushings I noticed that the instructions call for installing the metal sleeves inside the bushing upside down from how they were originally installed.
They come installed flat side down and shaft up, but instructions call for " install from the top down" .
I installed as instructed, but I have been wondering about it. second seems a bit harder to engage at WOT.
I also have AMS under hood bushings. Also installed Works shifter with their bushings.
I have heard of people having difficultly/problems shifting from using solid under-hood bushings. Might be worth double-checking that those are installed correctly and maybe swapping the stockers back in to see you what that does it for you.
i installed the works shifter console bushings. the console moves a little bit side to side but i tightened the 4 screws alot but do no want to over torque it? is it soposed to give a little?
Kracka
83
Jan 20, 2017 12:54 PM
BoostNY
Dec 17, 2016 02:31 PM
silver fly
Mar 11, 2010 11:23 AM
TommiM
May 10, 2009 07:33 PM
