Info: Works Evo X *upgraded bov*
WORKS Diverter Valve - 2008+ EVO X
The WORKS Diverter Valve is an OEM-style unit featuring all-metal construction (except internal diaphragm). The DV utilizes a unique internal design to balance maximum boost pressure regulation while maintaining excellent drivability. Special fastening hardware ensures a superior airtight seal.
Holds upwards of 30psi (when properly installed) and since 100% of the discharged boost pressure is returned back to the intake, the WORKS DV ensures the best performance possible.
You cannot get a better EVO X valve for performance, reliability and daily drivability.
Application: '08 EVO X including GSR and MR
QUESTION
ANSWER
Our Diverter Valve does have uprated internal components. We've used in on cars up to 29 psi without failure.
The other option would be to go with a GFB recirculating style Blow off Valve, they are adjustable as to how much they weill vent, so you might be able to adjust it to full recirculate and not have issues with the light. They are rated around the same 30+ PSI I think.
Hope that helps,
WORKS Team
sales@worksmotorsports.com
WORKS
Infineon Raceway L-1B
29673 Arnold Dr.
Sonoma, CA 95476
T 415.226.2500
F 415.226.2501
www.worksmotorsports.com
This is a good option for people who want to upgrade their BOV due to running higher PSI on various turbos.
I say this is probably the best option for a recirc valve if you want to upgrade. Too many of these BOV cause a CEL to come on.
Just sharing some knowledge.
QUESTION
WORKS,
I am trying to figure out what your EVO X diverter valve consists of. It looks like a stock unit replacement, however are the internals changed out in your units to hold boost better. I don't want to buy another "stock" BOV that will hold barely 25psi of boost. I tried using a reciculated FORGE RS BOV on my car and I keep getting a CEL light for p1241 Torque Limit. The problem is the BOV will throw the code on uphills at part throttle switch to stock problem is eliminated. So I need a stock like replacement that holds boost much better.
Hope that helps,
WORKS Team
WORKS
29673 Arnold Dr.
Sonoma, CA 95476
T 415.226.2500
F 415.226.2501
I'd planned on getting one of these at some point, but it looks as though now is the time. I discovered just last night my *stock* Bypass Value is leaking boost pretty bad. I had initially assumed there was a leak somewhere in the plumbing, but after tightening everything down and even replacing a few of the T-bolts and one of the couplers, the BPV was the only thing left that could be responsible. I tested it last night by reversing the BPV (effectively making it a PULL-type valve) and viola, no more angry tea kettle.
Before I drop money on the WORKS valve I'm going to look into maybe just swapping the stock spring out for something stiffer. We'll see...
Regardless, the stock unit is pretty capable, and I have heard good things about slightly crushing it, on the 9's anyway.
I assume you would be able to see if you were leaking boost on the dyno yes? Like your boost graph would be all jagged or just crap out and the power graph would represent this as well?
Yea I wasn't referring to holding 30psi, but I don't know if I have seen anyone running(holding) 30psi at redline even with an upgraded turbo on the X yet.
I can post some screenshots.
On my personal evo, many moons ago, I had it tuned at 29psi peak but couldn't tune out a rich spot at peak boost. So out of curiosity, I crushed my Bov and went out for a log. The car hit 34psi before I let off (I had error correction off for this) with no other changes at all. So same WGDC, same everything. I tuned it back down to my target 29psi and the rich spot also went away.
Usually you can't see BOV leaks in power curves unless they are extreme.
I've had some great gains on the 9's from crushing bov's when trying to max out the stock turbos on E85. I had one 9 gain 40whp/40whp in the midrange from crushing the bov and no other changes.
I had a Evo 8 with a 35R gain 50whp up top from changing to a bov that wouldn't leak with 30psi sustained to fuel cutoff.
Chris@nolimitmotors
447
Dec 26, 2018 05:09 PM
FS[West]: OEM EVO IX metal dv bov diverter valve
fugiwara
Jun 1, 2016 03:13 AM
Clipse3GT
18
Dec 16, 2009 03:48 PM
xtnct
12
Jun 14, 2007 09:21 PM
