A Couple Exhaust Questions
I searched around for some info on this and came up empty handed, so I'm just going to ask it. For those of you who upgraded to a catback exhaust, then at a later date to a turbo back, how much louder is the turboback vs the catback? Any advice is welcome, although those who upgraded to the ETS V2 CB, and then to the ETS V2 turboback, or those of you with non resonated exhausts, would be particularly helpful
And I've heard mixed opinions, so that is what I will probably recieve here as well, but is it worth upgrading the 02 housing and downpipe, or will this not yield significant gains...
Thanks In Advance
►EX◄
Thanks In Advance
►EX◄
As far as the gains go by adding a downpipe...it depends on who you ask. Some say very little to none at all. With that said, I upgraded anyway. The addition of the downpipe the car sounds exactly the same to me.
I had the stock O2 downpipe and cat with a catback. I then installed an aftermarket O2 downpipe and a high flow cat on the same catback. It wasn't super loud and obnoxious, but it does get a little louder. I like a decently quiet exhaust that you can still hear a little while cruising but gets aggressive at WOT. With that said, the full turboback is still bearable to me for daily driving, so I'm happy with it.
I've been reading up on this a bit. The consensus seems to be that the DP doesn't add much power but it does improve spool. It is also considered a pain to install--some people have broke exhaust bolts getting the stock piece off, necessitating pulling the turbo. I'll be having a shop put mine in.
Thanks In Advance
►EX◄
Thanks In Advance
►EX◄
►EvolutionX◄
May 25, 2015 07:42 AM
WTB[Northeast]: ►TRE Built Rear Diff◄
XSilverJ
Jul 2, 2014 05:41 AM
XSilverJ
Aug 31, 2013 10:33 PM
