X GSR Oil Cooler Specs
Bump for answer as I am interested as well. Mine is bombarded with rocks especially from the side that faces the wheel well. I plan on removing all the rocks and straightening the fins this weekend to get airflow back up again. I'm also going to zip tie a finer mesh against the plastic wheel well so that larger rocks aren't beating up the core so badly.
From the front I also noticed that the ducting isn't really complete leading up to the Oil cooler either and I may try and seal it up better so the airflow is forced through the core.
It would be good to see what aftermarket cooler upgrades there are that will fit the Evo X.
Roen
Mitsubishi TC-SST Discussion
Mar 19, 2014 08:29 PM
ghoonk
40
Jul 2, 2007 07:37 AM
talentsearch301
Jan 29, 2007 07:59 PM
