Transfer Case oil?
I have crossed this a few times over the years.
They use scare tactics such as saying it will void the warranty to keep you buying their overpriced fluids.
LG
Transfer Case Oil
So what I gather is that as long as the gear oil for the transfer case is rated at GL-5, it should be acceptable for use? The oil weight containing or limited to 90W is also a factor, of course. This would place several oils in the acceptable category for use.
Redline, Valvoline Synthetic, AMSoil, Mobil1, Royal Purple
(reasonably new to the import side of vehicle performance )
Any GL5 rated 90w oil will work in the TC, as long as it is rated for limited slip use to allow the clutch pack engagement to properly occur. I suggest synthetic oils as the diff and TC capacities are abysmal so a high quality synthetic would be beneficial.
I use Mobil 1 Gear LS 75w90 in my TC and diff. Its great stuff and not expensive!
Grilla
Mitsubishi TC-SST Discussion
37
Apr 8, 2021 11:00 PM
rydogg008
May 23, 2016 03:27 PM
