uhhh ohh help me my turbo is OUT!
so im going home from work today and i hear a sound (seemed like under the hood) (whoosh noise) and now my turbo will not kick in. motor still running everything is okay, but NO TURBO~!!!! i drove home about 50mph on highway for about 30 miles. I have checked uicp, licp, and boost controller... everything seems secure. any help would greatly be appreciated... sorry i am extreme n00b
btw... i have fmic, uicp, licp, boost cont. full exhaust, cone filter, cobb access port
sorry if i am leaving any info out... again SUPER NOOB
actually... i just cranked my car today and the boost is back on??? what the hell is going on? everything seems normal again... boost is still peaking 25psi and all... im kinda happy at same time freakin out... wat is this
I would still check all your couplers. My guess is one came loose somehow and is on the verge of popping off again.
Your turbo will just not decide to spool one day and then come back another and then go back out. The turbo will either work or it won't. If it's working now then you had a boost leak and need to find out where it was because it will probably happen again.
Do a boost leak test if you can. Take your air filter off, get a large, thick zip-lock back and clamp it around your intake tube. Use the vacuum source off your blow off valve, and if you have access to an air compressor, compress the air into the vacuum source and listen for any leaks. My car leaks a little through the MAF sensor on my hardpipe, and sometimes after a few pulls, the car will go into limp mode making it feel sluggish, and only boosting 11 psi. But a boost leak test will narrow your culprits down when trying to find a loose coupler, loose vacuum line, or a damaged intercooler.
My guess..... You were cruising at 50+mph you said.... I bet you gave it some gas in 5th gear, the car overboosted because of your MBC, which caused your car to go into limp mode.
I see your list of mods, but i don't see a tune.... so I have a feeling my conclusion maybe accurate.
First time I had a pipe pop off I had just installed my new turbo. Was driving it around on minimal boost, but one time i decided to turn it up and have a pull. Drove past a bar at like 28 or so psi and the bottom intercooler pipe popped off, the people on the gazebo thought I was shooting up the place or something... I had to drive 5 mph to go home which was over a half mile away. I felt and looked like an idiot.
Should be just a leak somewhere, but yes, murio is right, check all the couplers because if you don't find it it will happen again when you need the pressure the most, which on the highway is not safe at all...
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
