So, while I have the hotside off, anything I should do? Porting?
Ya so the old busted (again) o2 housing came off easy, but getting it back on proved that it came off a bit too easy (a couple of the bolt holes in the hotside got their threads in a mess).
So... while I've got the hotside and exhaust manifold off (AGAIN!), what should I do?
I'm already:
- fixing the threads ()
- pulling the studs in the manifold to replace with bolts
Should I looks to do a DIY port/polish? I lined the manifold up with the gasket and it looks like there's very little material that would need to come off (if any) in order to get the ports to match the gasket, so I'm not sure of the gains in taking the time to do that.
And don't say "put a red on." Believe me, I've thought about it... but I'm tired of spending money on the car at this point.
I'm already:
Doing a port and polish by smoothing out casting marks and other features that may slow flow should help. In general you want the head to match the ports and then taper down to where it enters the turbo to increase velocity overall. The stock exhaust manifold has passages facing each other which doesn't help flow but smoothing the inside radius leading to the turbo should give the exhaust gasses a chance to turn towards the turbo inlet earlier and help it flow a bit better.
[WTB] Oem hotside prefer 10.5
cerevo
Dec 6, 2016 10:12 PM
recompile
10
Apr 20, 2008 08:39 PM
evil mechanic
18
Sep 4, 2006 10:17 AM
