who is seeing better gains in what cams. . .
Old Apr 16, 2010 | 05:11 PM
  #46
monkey_187's Avatar
Anyone have info on the GSC S2's? I am looking into getting cams but am undecided, its either:
JUN
GSC
Kelford
Old Apr 16, 2010 | 05:39 PM
  #47
Clark_Kent's Avatar
I'm expecting good things from the GSC cams. Hopefully someone will give these a shot.
Old Apr 16, 2010 | 05:44 PM
  #48
murlo26's Avatar
^ETS used them in their big 768whp or whatever it was build.
Old Apr 16, 2010 | 05:53 PM
  #49
Clark_Kent's Avatar
Yes. I've discussed them with Michael some time ago and he mentioned the cams picked up a sizeable amount of power over stock cams. I would just like to see how they would perform on something a little more common, like say an FP Red, Green or a BBX turbo. At those power levels its difficult to determine how they will perform on something a little more mundane in comparison.
Old Apr 16, 2010 | 05:59 PM
  #50
murlo26's Avatar
I am debating about switching out for some gsc2's for when i put valve springs in. I figure if i am in there anyway mind as well throw some bigger cams in.
Old Apr 16, 2010 | 07:22 PM
  #51
Fishstix's Avatar
Stage 2R Jun cams go in this Monday
Old Apr 17, 2010 | 09:44 AM
  #52
monkey_187's Avatar
I might be the one cause nobody will tell me where they are getting the JUN cams from. Those are the one but it must be some big secret the place the get them from.
I will post up my results when I get them, it will be a couple of week. I have to wait till I get all the parts so I can install everything at once.
Old Apr 17, 2010 | 01:26 PM
  #53
Fishstix's Avatar
Ask a vendor duh.
JUN cams are double the price of the USDM ones available though.
Old Apr 17, 2010 | 11:11 PM
  #54
monkey_187's Avatar
Originally Posted by Fishstix
Ask a vendor duh.
I have but I want to know what kind of deals others have gotten. After all isnt that what we are here for to help each other out. with a comment like that you seem like the type that would get a deal and keep it to yourself.
Either way thanks for the advise.
Old Apr 18, 2010 | 03:30 AM
  #55
weap0n's Avatar
Please post results Fish when they come in.
Old Apr 18, 2010 | 04:54 AM
  #56
Clark_Kent's Avatar
http://z1auto.com/prodmore.asp?model...ne&prodid=3252
Took 10 seconds.
Old Apr 18, 2010 | 05:11 AM
  #57
.RYAN's Avatar
AMS suggested Kelford or GSC with the FP Red.
Old Apr 18, 2010 | 01:48 PM
  #58
Fishstix's Avatar
I did get a deal and I stole it from everyone
I've advertised several times across the forums that I got my cams used from my distributor. 200 miles used. $700. MSRP $1700. steal
Old Apr 18, 2010 | 07:36 PM
  #59
DRAG's Avatar
The problem I have seen from BC cams in general (not just evo) is that the centerlines are all off. Some cams are off 6 degrees, some 12, some 18, etc. EVO guys don't degree their cams in. They stand 10 feet away from the car and throw them at it until they take a good bounce land in the engine in the proper orientation. So with crappy cam grinds and not degreeing anything they are opening the valves at the wrong time and they lose power. If you adjust for the f'd up cams they will probably make good power. Either way, the quality control in general is teh suck. I'm not sure about 4B11 cams, but that is just what I have seen over the years with those things.
I'm going to run the stock cams until I get the car into the 10s then I will probably try some kelfords. I have used Kelfords on other engines and at least they give you exactly what their sheet says on it. I know they also spend time making sure their cams aren't doing funky slack and tightening bull**** with the chain and tensioner, which is important on these chain driven motors.
Old Apr 19, 2010 | 03:17 AM
  #60
JED_POLAND's Avatar
I wish I knew it before I bought BC...
Quick Reply: who is seeing better gains in what cams. . .
