About oil change and engine flush
Hi guys, I'm going to do my first own oil change. So far the dealer did 3 times oil changes for me, but suddenly I figured they might not change the oil filter and didn't really drain the oil completely every time,and I'm a little behind schedule for this oil change,so I'm thinking make I could do a engine flush. But IDK if I can do engine flush on a turbo car, and if it's necessary or good to our engine. If it do no harm to our engine,what's the recommended brand?
Condition of my oil: I changed my oil every 6000km, but before
every oil change, the oil was quite dark( not totally black, my car has only 17000KM).
I'd flush with a synthetic that you are willing to use long term..so it would cost 5 qts...otherwise, don't use cheap oil for anything unless its an emergency. You'd be better off just changing the oil a little early the next couple of times. The new oil will have a fresh additive package that will keep the contaminants in suspension so it is somewhat psychological to need to see really clean oil.
the other thing is the evo blackens the oil quickly anyhow.
BTW- don't flush with a chemical cleaner! (re-read your post)- just put fresh oil in, drive it 'till its warm, then drain and refill-or just do what I recommended and just change the oil a little early next time.
Freebs
Mitsubishi TC-SST Discussion
Sep 4, 2015 10:08 AM
RA2013
Jun 19, 2015 07:43 AM
