boost leak test
boost leak test
hi I am trying to DIY boost leak test. does anyone know which location I should start to hook it up? and what diameter should i use? I have searched alot but there is no one for evo x. I made a two inch tester
I hooked it up to UICP, and air was entered constantly until 25psi. it slowed down to zero. I did several times but i heard anything from there. but my boost still peaks 13 psi with no tapering. is there other restrictors to raise the boost level such as boost pills or Solenoid?? I am using AP stage 1.
My understanding was that you need to take off the intake and hook it up (i.e. turbo inlet). This is what I was planning on doing when I finish building mine.
Sorry, I think it is 2.5 inches, not three. The intake reduces down in size when it gets to the turbo. Someone correct me here if I am wrong.
i heard there is an o-ring in the turbo oil line that can get displaced if you pressurize the crank case too much. Has anyone experienced an oil leak after doing a boost leak test?
partyboy1122
13
Jul 28, 2009 02:11 PM
BCOZEVO
Aug 10, 2008 10:10 AM
