What is a good coolant?
Just be aware that part of the reason people use some coolant is for corrosion prevention so you may have to change that water out every 6-12 months. Water Wetter has some corrosion prevention in it's mixture and does indeed increase the amount of heat transfer that is possible between the fluid and the radiator core for increased efficiency.
i run straight distilled water and 1 bottle water wetter. i have done this for over 4 years. never had one issue. running straight undistilled water is not good at all. you need to use distilled water.
