Ets t3 twin scroll turbo kit or ap t3 twin scroll turbo kit?
Old Nov 22, 2010, 01:03 PM
  #31
ETS Michael's Avatar
Originally Posted by VGergo
FP said they can make the HTA for ATP Garrett Dual Ball Bearing Twin-scroll GT3076R, with an ETS manifold and 3" o2 house/downpipe it coud be a great offer too. What do you think ?
But yes ETS TS HTA3076 is kit.. just bolt on with every accesories.
Stock turbine housing? It's too small for any real power.
Old Nov 22, 2010, 01:04 PM
  #32
murlo26's Avatar
The X stock turbine is too small? If that is your stance I would disagree
Old Nov 22, 2010, 01:20 PM
  #33
I have an FPBlack here and I can see why it gets choked up A larger turbine housing is definitely beneficial with an upgraded turbo.
Old Nov 22, 2010, 01:24 PM
  #34
murlo26's Avatar
No arguments there, but you lose spool too...different strokes for different folks
I guess I just thought a 600whp capable turbo isn't anything to shake a stick at.
Old Nov 22, 2010, 01:28 PM
  #35
It may be capable of making peak power at 600whp but maintaining it to red line is a different story
Just an example.
Stock Block, Stock Head, Stock Cams (non opened motor)
Standard 35R 22psi = 457whp (Dynojet)
Standard 35R 32psi = 614whp (Dynojet)
On a black, it's going to take damn near 40psi to make 600whp plus a built motor.
Michael
Old Nov 22, 2010, 01:35 PM
  #36
murlo26's Avatar
You should be building the motor regardless at 500+ anyway.
I am not at all trying to say a 35r is a bad idea...lord knows I will probably end up with one on my car shooting for 700whp...then 800whp in 2 years...then my dumb *** will probably be in the gutted X with cage slicks and 1000whp in 5 years...lol
I am just saying the black is still a great turbo option for a turbo that can spool up at 4k and make some great numbers...I make my 570whp at like 7500ish. Holding over 500whp for 3krpms and with the spool I have I am looking at almost 5k of powerband...But as you can see from the torque curve, it is choking out up top, I am hoping a nice tubular mani will keep that torque going more and I can hold peak power out further.
No denying that my setup with a nice basic 35r would make power stupid easy. I bet at 32 psi my built head/cams I make closer to 700whp where yours made 615...so yea might be a smart move....
Old Nov 22, 2010, 01:49 PM
  #37
Ya, our numbers were on a standard 35R. I doubt a standard 35R is going to make 700whp We did run an HTA3586 at 33psi and made it in the 700's, but I was comparing a turbo that spools like the black.
We were able to get a 35R w/ .63 A/R to spool around 4000-4200rpm and pull all the way to 9k RPM. This made for a great street setup. Also the torque was pretty amazing.
I guess the debate is up in the air. For me... I would rather buy once then buy twice. If you start with the 35R it's easily upgradeable to an HTA3582/86
Also at 18 psi with a 35R we were over 400whp, it's not a bad way to start out with lower then stock boost levels.
Michael
Old Nov 22, 2010, 01:55 PM
  #38
murlo26's Avatar
Well your kit has a nice tubular mani though, which helps top end a lot over a stocker When I get one of those, I will decide if its stupid to do a black or just go right for the 35r...I agree a 35r is a much easier way to do it...its just easier to buy parts piece by piece.
I had no intentions of going this far with my car...blowing up a motor changes things.
Old Nov 22, 2010, 04:16 PM
  #39
chkmgnt59's Avatar
I don't want to jump too far in to this debate, because obviously a 35r will make more up top than a black. But... at 18psi, on the black I made 390 on a mustang, so over 400 at below stock boost there as well :-)
And for the guys who already spent thousands on bolt-ons, the black provides a good path. If I were totally stock, the only option would be ets 35r kit. But I was already invested, and I don't think I need more than 600whp, which the black can get me to :-)
Old Nov 22, 2010, 07:14 PM
  #40
murlo26's Avatar
Yea i think i was over 400whp at wastegate as well
Old Nov 23, 2010, 01:45 PM
  #41
VGergo's Avatar
Michael
I would really see that 35R what coud spool in around 4000-4200rpm. Is it on 2.0 ? Because than on 2.3 stroker it will be a magic power band
Old Dec 9, 2010, 03:34 AM
  #42
VGergo's Avatar
ETS Michael !
Can we choose your twinscroll evo x turbo kit with GTX3076 in HTA ?
Old Dec 9, 2010, 05:29 AM
  #43
chkmgnt59's Avatar
gtx3076 HTA? no such turbo exists. you can get a gtx3076 though from them.
Old Dec 9, 2010, 03:38 PM
  #44
project_skyline's Avatar
ETS Michael !
Why would you want to replace the wheels of your GTX with HTA ones? Thats what it does so there would be no advantage just a waste of money.
Old Dec 10, 2010, 10:27 AM
  #45
RB185AFM's Avatar
You guys are all wrong. You need a ETS single scroll with a 6262. Oh wait I may be biased. My bad.
Quick Reply: Ets t3 twin scroll turbo kit or ap t3 twin scroll turbo kit?
