Downpipe/02 removal help
I'm having trouble getting the stock head shield removed that is underneath the Downpipe. I believe this shield needs to be removed so that you can get to that lone bolt that is the only one out of the 5 that is in the opposite direction.
There are 2 bolts on the bottom of the DP that holds the heatshield on, how in the f do you get at them? No socket fits in there and I've been trying to get at it w/ a box end (ratchet syle) wrench on there and just dont have enough room. Are there additional pieces I should remove to get at it? I havent removed the cross brace but I dont see that giving me that much more room. I also tried bending the shield out of the way to get at it better but still cant get a good bite.
Tried searching some but couldnt find any techniques other than people noting how much of a pain in the **** this thing is... man is it. I already broke the front 02 sensor, that was a $400 curse word right there. Any help is appreciated.
EvoM Community Team
Check this: https://www.evolutionm.net/forums/ev...placement.html
Click on the "how-to" link in that thread.
Or, try this one: https://www.evolutionm.net/forums/ev...tallation.html
Or, here's a quick search I did (did Advanced Search; put in "downpipe" and chose the "how-to Evo X" section) with plenty of results: https://www.evolutionm.net/forums/se...rchid=12308311
Yeah, those are tough. We did remove the brace and everything else that'd give us some space.
we did one yesterday with the 2 wrench method... they are a pain for sure, but honestly... if i ever did anything like that to a X, id upgrade the turbo at the same time. It is such a pain in the dingaling, i'd only want to go in there once
thanks, I'll take a look through some of em. I'm not sure about wrapping a tow strap around the neck... I'd be afraid I'd actually hang myself with how frustrating this thing is.
I'm sure I've used the "2 wrench method" unknowingly but what do you mean? Putting a box end on the end of the wrench actaully on the bolt for more leverage? Thanks for the feedback guys... now just need to get another 02 sensor from RussellM
Registered User
If it's the same heatshield I'm thinking of, while underneath the car stick your right arm in through the wheel well. Seems impossible to do, but there is enough wiggle room to get it through. But, unless you are very strong, you need a longer wrench to give more leverage. I got a set of ratcheting ones from Loew's that are longer than usual, it worked well for me.
Update... for anyone searching this in the future. Remove cross brace, shield over brake lines (I think that's what they were) and then another shield that is bolted to the transmission/diff, then use PB blaster. My god that stuff makes a HUGE difference. I used a ratcheting box end wrench to get the 2 heat shield bolts off on the bottom and the backwards DP bolt. I managed to get all bolts including the 5 DP w/o breaking any of them.
just know though that you will need a new bolt/washer/nut for the one lone bolt that is backwards (its the one thats in the worst location). Reason being that on the Stock DP it is ONLY a nut... Theres a fixed stud into the DP.
DeweyD
Evo X How Tos / Installations
Apr 26, 2015 07:08 PM
reboundicon
Apr 20, 2011 04:20 PM
