Need a clutch education before switching
The member who posted about MT90 oil drives a CT9A (from his signature). MT90, last I checked, is not recommended for the CZ4A due to different metal composition in the drivetrain parts involved. I also remember reading about Redline recommending a mix of couple of its oils for the CZ4A. Only way to find out is to research a bit more before you jump on the redline bandwagon and ask Redline directly if needed. I may be wrong, but just thought you should know about it.
expect to pay about $500 in labor to do the install for the install. Sure you can probably get it done for a bit less, but i'd rather shop around by reputation instead of price for this.
I'd also suggest getting a flywheel and clutch together as a kit instead of pairing them on your own unless you really know what your doing and what results you want/should expect from the pairing.
I'd say get an upgraded master cylinder at the same time if you are getting a clutch that has greater clamping force. Either the 8/9 one or the SSP one. There have been a ton of posts on here about guys splitting the master cylinder from increased clutch pressure (from a stronger clutch).
I am leaning toward the Exedy stage 2 Cerametallic, or Fidanza 2.1 Carbon Kevlar, and SSP master cylinder. I still don't know which flywheel I will get. But I will definitely get a lighter one.
Pure Playaer
32
May 5, 2013 09:23 PM
Tango|EVOLUTION
61
Jan 17, 2011 04:52 PM
