mil spec or ams cat?
I've read posts from people with a 100 count HFC stating it fails sniffer tests at state inspections. In addition they don't fully eliminate the smell you get from running a test pipe.
These reasons are why I went with the AMS 300 count HFC, plus their reputation for making high quality parts. I get no smell from my AMS HFC, it comes with two metal gaskets, fitment was perfect, and it has an extra bung for an A/F sensor.
Not sure about the milspec, but I have the AMS HFC and love it. Use to run the SX resonated test pipe and I would have to agree with you that the smell can be a little to much at times. Only draw back with the AMS is that I had to chop off one of the 3 bolts that holds a shield for the driveshaft cover. No biggie easy to do and the cover sits perfect with no rattles.
looking at the pic it is the heat shild behind your hanger and cat. It has some speckled surface rust on yours. There are 3 bolts. 2 on the bottom and one pointing right torward the cat. That one (maybe because of my exhaust setup, Cobb SS) I had to chop off or during bumps it would hit the cat. real nasty rattle!!
