View Poll Results: Center diff pins
No issues
139
79.89%
Upgraded prior to pins breaking
11
6.32%
Pins backed out no tranny failure
4.60%
Pins backed out w/ tranny failure
16
9.20%
Voters: 174. You may not vote on this poll
Center Diff Pins
Old Apr 12, 2011, 05:37 AM
  #76
Spazo's Avatar
Hey Drastik, did you happen to take pics of the entire process? Pics of the shep pins? Why'd you use the shep pins over, say, the Baschur?
Thanks!
Old Apr 12, 2011, 06:51 AM
  #77
DrasticK's Avatar
Thanks!
Sorry, I actually went with the Buschur pins/dowels, not shep. There is a good guide on the other forum if you google "center diff pin swap".
Old Apr 12, 2011, 07:02 AM
  #78
Spazo's Avatar
What was your reasoning behind going Baschur over the Shep pins?
I'll see if I can find it over on "the OTHER forums"...
Old Apr 12, 2011, 07:14 AM
  #79
DrasticK's Avatar
I didn't like how the Shep pins were just OEM pins. I don't know which one is better, or if anyone knows, but for now it helps.
Old Apr 13, 2011, 08:42 PM
  #80
CliveW's Avatar
My new revision 1 pins, EN30 steel, hardened to 60HRC, ground to size, titanium nitride coated, multiple spiral oiling grooves force fed from gearbox oil bath. Made in standard size and 0.2mm oversize for replacement where gear internals are damaged, in this case, the gear internals, centre diff case and centre block are ground to the correct oversize. Also tool steel retaining pins.
Old Apr 14, 2011, 08:18 PM
  #81
PR_Mivec's Avatar
^^ id love those
Old Apr 15, 2011, 05:55 AM
  #82
techmaster's Avatar
Originally Posted by warmmilk
For the 2011 owners out there, I shipped my did out to Shep trans to get the upgraded diff pins and Torrington bearings. He said that the diff pins were the upgraded ones stock. Sonic you have a 2011, chances are you have the good pins already.
So did you get any other work done to the diff or tranny, or did you just get it all shipped back to you stock because it already had the new, upgraded pins? Just wondering because I have a 2011, and I would love to not have to upgrade the pins when I do my clutch down the line.
Old Apr 16, 2011, 09:18 AM
  #83
tephra's Avatar
wow they look great.
i will be after a set or two of these in the near future...
Old Apr 16, 2011, 01:30 PM
  #84
Bear.914's Avatar
You will also need the Torrington bearing upgrade, just contact Trevor from Shep Trans @ Trevor@sheptrans.com and he will assist you
Old May 15, 2011, 02:55 PM
  #85
sheeley91's Avatar
has anyone verifed that the SST does or does not have this issue as well?
Old Jun 3, 2011, 11:51 AM
  #86
myersap93's Avatar
Would also like to know this
Old Aug 12, 2011, 04:39 PM
  #87
LVSBB6's Avatar
^Bump for answers regarding SSTs!
Old Aug 14, 2011, 09:52 PM
  #88
dangina's Avatar
would like to know this as well - looking at buying a 2011 or 2012 model and hope that they have solved this issue by now...
Old Aug 17, 2011, 11:14 AM
  #89
m7mad.a's Avatar
can somebody provide me the link to the center diff pins replacement how to?
I can't find it again
Old Sep 3, 2011, 05:08 AM
  #90
dangina's Avatar
I've read that the 2011 have the diff pin upgrade - was wondering if the 2010's have it as well?
Quick Reply: Center Diff Pins
