Which has less noise - HFC or Muffler test pipe?
i've been pondering this for a while - which will create less cabin noise? HFC or a muffler test pipe? considering one slows down exhaust flow and the other being a big muffler that is very capable of canceling noise, i'm really not certain which one is more suitable when cabin/exhaust db level is concerned. see, i've ridden in a car with the quietest aftermarket exhaust i know to date - T1R 76S, and there's still some noticeable noise in the cabin. that car had a test pipe on. if i was to reduce cabin and exhaust noise even further, without going back to stock, which route would be more appropriate?
I'm really thinking a HFC would produce more noise in the cabin...I will be putting a resonated test pipe on in a few weeks (currently have a AMS HFC)...I'll update this thread with my results.
just b/c you can see straight thru ur muffler doesnt mean it flows that way. Exhaust gases are in pulses and are high in temperature. Dont you think hot gases would want to expand? Exhaust gases expands thru those perf tubes and doesnt travel stright thru your muffler. How do you think sound is absorbed by your resonator/muffler? hummmm things to think about now. hehehehe just my 2 cents
1 Post
DaFastOne is pritty much on the money, granted the strait through muffler isn't as good as the restrictive style OEMs use by redirecting exhaust gases to take a longer route and through more material. So I'm sure the the resonated/muffled test pipe will be quieter. But if I were you conact the MFG of the test pipe you want and ask for a flow rating and db of there product, a good company should have done R&D to provide the beat product possible instead of something slapped together.
Jmk0601
10
Apr 26, 2015 10:06 PM
dkorr
Feb 8, 2014 04:40 PM
Kasander
23
Sep 28, 2009 12:52 PM
