injecters and fuel pump for e85 fp red
Old May 10, 2010 | 02:06 PM
3dman1's Avatar
I need help im buying injecters and a fuel pump for a e85 set up on a stock turbo but i have the future goal of e85 on a fp red and i need sugjestions on injecters that will work for both setups. Will a walbro in line work for 1500cc injecters on e85 fp red? and will i be able to get a decent tune with this size injecter on a stock turbo? It may be a while before i go red especialy if i like the e 85 stock turbo set up. Help?
Old May 10, 2010 | 02:12 PM
Huge's Avatar
I just received these (1500cc) injectors from deatschwerks and will be getting them tuned this next week. ill let you know but my tuner has no doubt he should be able to tune them without any issues.
Old May 10, 2010 | 04:46 PM
mlomker's Avatar
It's trying to run pump gas on large injectors that is problematic. If you only run E85 then you'll be fine.
Old May 10, 2010 | 06:40 PM
Evofreak21's Avatar
Im in the same boat your in right now, tryin to figure out what fuel setup to go with for E85. DW1500 come, that will give me plenty of room for and upgrade in turbo.
HUGE are you getting tuned with E85? Also if you dont mine can you PM me the price of the DW1500?
Old May 10, 2010 | 07:17 PM
murlo26's Avatar
I ran the Dw1000cc injectors and 255 fuel pump for stock turbo e85.
The upgraded to the blaqop's double pumper for the Fpred and i had enough fuel.
Old May 10, 2010 | 07:43 PM
tephra's Avatar
Regarding a single walbro:
a 255L/h pump is only good for 1060cc injectors
do the math
Old May 10, 2010 | 07:45 PM
murlo26's Avatar
do the math
Was that directed towards me? I switched to a double pump for my FPred
Not to mention I have an AFPR setup for upping base pressure if needed.
Old May 10, 2010 | 07:53 PM
tephra's Avatar
no - it was directed at the OP
Old May 10, 2010 | 09:11 PM
3dman1's Avatar
i think im asking to much for injecters im looking for a way to run anything from a pump gas stock turbo to e85 on a fpred all in one injecter.Can i tune a 1500cc injecter for pump gas on a stock turbo. I would like to be able to use pump if e85 is not availiable and not be stranded. and have room for the future. Is it possible?
Old May 10, 2010 | 09:14 PM
tephra's Avatar
you will need 1500cc to run E85+FPRed
any good tuner will be able to tune 1500cc on pump+stock turbo
Old May 12, 2010 | 12:52 PM
DeatschWerks's Avatar
We've had good reports of good idle and low throttle driving from the thousands of EVO and Sti 1000cc injectors we've sold all over the world, running both E85 and Gas. We've been getting similar reports back from our beta testers of the 1000cc+ line we'll be introducing shortly. We getting excited around here, and look forward to hearing about some of the awesome setups you guys have in the works.
Chris
Old May 12, 2010 | 12:55 PM
Evofreak21's Avatar
DeatschWerks send me a set of 1500, I will gladly test them for you.
Old May 12, 2010 | 03:59 PM
3dman1's Avatar
Are the Deatsch Werks 1500cc avaliable yet?
Old May 12, 2010 | 04:04 PM
CatalystGod's Avatar
Just noticed this was the first post ever under that username by DeatschWerks. Now how about pricing those injectors to be cheaper than the subie guys!!!!
Old May 14, 2010 | 02:56 PM
The 1500cc's are coming guys! TRUST ME! We are just as anxious to get them out as you are to received them. When I say they are coming, I do mean in a few weeks, not a few months. So they are close to getting out the door. As soon as I get the green light, you guys will be the first to know!
EDIT - Oh wow, that was the first post. Was it a good one?
Quick Reply: injecters and fuel pump for e85 fp red
