Clutch Slipping
Clutch Slipping
Hey guys, my dad and I just bought a used 2008 Evo X GSR to share with 30k miles on it. After having it for around a month, we noticed a more common smell that was unfamiliar to us and we just ignored. A few days ago however, the clutch began to slip and have problems and we had to get it replaced and it is still in the shop. Are other evo owners having similar problems, and is there a way to keep the new clutch working forever? And are performance aftermarket clutches a fix? seeing that to replace the clutch is $2100 and an exedy twin plate is $1200 installed... HELP! My father is very very stressed about his investment being a lemon.
Just swapped my clutch last saturday. here's the thread I made about it.
https://www.evolutionm.net/forums/ev...riences-x.html
Get a ACT 6 puck and you should be good
btw: cars aren't investments.
Clutches are items in cars that normally wear, so don't misinterpret the condition as the car being a lemon. The stock X clutches are known to be the weakest component in the drivetrain, and they have been known to start slipping earlier than many other clutches.
There are guys who claim slippage at under 10,000 miles; there are still other guys who claim that their clutches are still fine after 40k. Based on what i've read, you should feel lucky that the stock clutch lasted to 30k. Plus, you and your dad should have known better prior to buying the car anyway. If you're buying used, you automatically must assume that it has been beat on, frankly because the car is designed to be beat on and driven hard.
If you plan on doing any modifications to the car, get the aftermarket clutch. This, however, will probably void your warranty.
If you plan on keeping the car stock, then get the original OEM clutch.
How hard are you and your dad driving the car? Are either of you familiar with driving manual? I only get the burnt clutch smell after a hard launch and slipping the clutch to not totally shock the drivetrain. And even at that, it goes away after a day. I'm at 20k+ miles and it's still holding strong as day 1.
At 30k miles, if driven hard (or by inexperienced drivers), it's not unusual that the stock clutch will eventually wear out. It's not a lemon car, by any means. A lemon is a car that's always in the shop for parts falling off or CEL's popping off every 5 minutes. The X's are built pretty tough. Throw in an aftermarket clutch according to your future power plans and call it a day.
haha thanks guys. Ya my dad and I are both experienced manual drivers and i was getting the smell regardless whether I did a hard start or not. The rep at the mitsu dealer i got the clutch replaced at said that aftermarket clutches wear out a "cylinder that engages the clutch" and are very bad for the drivetrain... Is there some truth to this strange statement or does he just want me to pay to get the clutch fixed through mitsu?
i think he was probably talking about the cmc. it doesnt wear it out it puts excessive strain on it due to the higher clutch pressure. So in a way he is right.
just get a new aftermarket clutch that can handle some real abuse and call it a day.
now as to pick which one......hmmmmmm
is there a way to get a cmc to withstand the strain without wearing out? and is there a best clutch to replace with? I intend to install a fp red, manifold and so forth along with my current mods so the clutch needs to handle power well and be reliable. Thanks
DOUGLAS
Sep 26, 2011 08:27 PM
tsikisevo8
Mar 15, 2011 12:59 PM
