Tial Q Bov issues
Tial Q Bov issues
okay, my setup basically is..i took the LICP off and got the bov installed there..ran the hose to the stock place for the vac line. I have checked and checked again..it seems to hold decently at 28lbs when running WOT..but even at full boost, the bov only seems to flutter, no SHHH noise like it should..it used to flutter then make the shhh noise..now it just flutters, no matter how much boost..any ideas on what it could be? i checked the UICP(nisei) and the vac lines, the licp seemed to be a little loose, but i tightened it down, no difference. any other things i should check because im at a loss here.
if pics are needed let me know, thanks.
Standard spring pressure is 10 PSI which should be fine. I have run into an issue once or twice where it would stick shut but that was after long periods of use in cold climates with salt and stuff. And only happened when cold. Can you manually open valve with your hand?
i can try..but i doubt it..its only about a month old..i guess i could pressure test it to see if its leaking anywhere but id rather not waste the money on that if i dont have to ya know..any other ideas from anyone lemme know! Thanks
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
Dec 17, 2010 09:41 AM
ModifiedMR
Feb 13, 2008 02:58 PM
