Eric Morse: Official Evo X Build Thread
I would stay away from the Dom2, its surges a lot, get an FPgreen if you want that size turbo. Honestly, any of the other stock frames I would recommend over that...Fpred/green BBX/bbx lite.
Also I would say use a 3 port instead of the MBC, but MBC's aren't the worst idea out there.
I'd also say don't get the MX1's. Many trusted shops always recommend the kelford stage 2's or if you want big power the GSC s2's are great.
The Dom does seems like a bad choice unless you got one for cheap. If you're running road course (guessing since you're looking at suspension) then a Red or BBX might be your best choice. They both make some pretty stupid power on E85 and the spool advantage of the smaller turbos doesn't matter that much at track rpms.
If you're having Buschur do the tune, are they also doing the turbo install? They have a good t3 kit, and give you the choice of a few blouch, PTE and FP turbos. https://secure.buschurracing.com/cat...oducts_id=1560
I am not having buschur install anything I was going to put it all together and have them send me a safe map to drive it up there which I was told that they would not be able to do for me. So thinking about it now I'd have to do a mail tune deal like Jestr tuning on the entire car and just never know the power level to see if I'm making my goals or not, which isn't to terribly important but when your about to drop almost 10grand in parts on a brand new car you kinda want to know what its making.
So if I toss in the S2's and fp red on e85 with DW 1300's will I crack 500whp?
Id say wait for the fp black to get done all of its testing.Its already doing 530whp on pump gas and their is more left in this thing from what I read. Im also a big fan of GSC cams so id stick with the S2's. I see your list of parts but I dont see any internal work for the engine. With parts like you have in your list and a stock engine its only a matter of time before you have blown new car. The X is nothing like the 8 or the 9 with cast iron block that could hold 500+whp stock all day long. Think about looking into some rods, rings, pistons the rest of the internals before you think about 500+whp.
Are you sure they suggested the Blouch Dom 2, and not the Blouch GT600r? The MX-1's should be fine. Juns and GSC cams could be better, but unless you're fully rebuilding a stroker or something, I'd settle with MX-1's for the price.
but yea, if you're trying to go with a bolt-on turbo... bbx > fp red > dom 2 imo.
Thanks for the imput!
I looked into the Black but I can't wait that long I need the car running perfect before the end of the month. Whenever the stock block goes i'm gonna swap to a big turbo and built motor as well as shep trans/tc/diff. But untill that time comes I want 500whp stock block. I'd do it all at once but I need to get a replacement daily driver and put some $ into my bike.
What is everyone running rpm wise with cams and the BR dual valve spring kit? 8500rpm?
Yeah, you are right. I guess i'll see how it feels on 93 and hopefully it will be enough power to keep me hapy for spending the money. Right now I guess its at 250wheel which is absoutely pathetic and I can't stand it haha. I'm guessing another 180-200hp will feel nice and maby won't do e85 at all then and stress the hell out of the motor.
That right there is my issue. I am used to driving cars that pull all the way to revlimiter and pull best near the celing. The stock turbo is nothing but midrange which sucks on the track.
