SSP Master Cylinder 2 (Still Issues)
Old Aug 4, 2010, 06:22 AM
kwlevo's Avatar
indeed not hard to do at all, just grab a beer and go for it
i'm not having any problems over here with V2.
Old Aug 4, 2010, 08:29 AM
webshell's Avatar
I work all day, and had a garage with tools and a compressor until i moved into a condo. Can some provide that link to the install or maybe a quick list of instructions to take it out?
Old Aug 4, 2010, 09:45 PM
oraclesam's Avatar
I have the SSP MC2 and I have not had any problems with it. I thought I had a problem with it the other day but it turns out it is my throw out bearing. Chris was very helpful. I am sure if you contact Chris that he will be able to help you out. BTW, I first replaced my MC with a stock one and paid to have that installed. I blew that one and then ordered the SSP MC2. I changed out the SSP MC myself. It is not that bad. Took me about 2 hours to change out. Get yourself a bleeder though so that you do not need someone bleeding the system while you are pumping the clutch. Also, unscrew and remove the piece on the MC that connects to the pedal before you push it through the hole in the firewall. Then screw it back on after you push it through the hole. It will make your life much easier.
XRims
Evo X Dyno Results
131
Nov 29, 2011 06:31 PM
vlncecast
15
Dec 5, 2010 08:57 PM
batmanlee
Lancer Tranny/Drivetrain Tech
Nov 3, 2010 11:17 AM
oraclesam
10
Jul 4, 2010 08:37 AM
wilbdog
13
Mar 23, 2010 12:05 PM
Quick Reply: SSP Master Cylinder 2 (Still Issues)
