Air magicly entering the clutch line?
Old Aug 12, 2010 | 01:36 PM
pyrofire127's Avatar
ok, so im flat out of ideas...
My clutch petal drives fine for about a day or two then starts dropping. I'm pretty sure its air in the line because if i bleed it ill get another day or two out of it
I have an Exedy 3puck and the SSP master cylinder V2
Somehow air must be getting in the line and i cant find it. I've had the SSP master looked at by SSP and it was fine. and i've already completely replaced the slave cylinder and i still cant find what could be causing the issue...
anyone got any ideas?
PLEASE POST if you have ANY random ideas!!!
Thanks!
Old Aug 12, 2010 | 01:41 PM
boosted2x2's Avatar
is the fluid level dropping? if air is getting in then fluid should be leaking out somewhere. if not i would say the slave or master is faulty.
Old Aug 12, 2010 | 01:50 PM
I dont think its dropping, i've been watching it but i've also been bleeding it enough its hard to keep track of, but ill watch it over the next 100 miles and see.
As for the master or slave, what are the chance of having a bad master after having it rebuild and being bad again. last thing i want is to raise question about SSP's V2 master, i really dont think that could happen twice. and the slave is brand new from Mitsu.
What are the chances of a new slave being bad in the same way as the old one
Old Aug 12, 2010 | 02:46 PM
tildeathdouswat's Avatar
I think you need to use an auto bleeder. I have the SSP MC2 also and bled the fluid , letting it fall into the engine bay/undertray (put shop towels to catch the fluid) and i have the same problem. The pedal gets stuck to the floor or halfway about twice a day for me.
Or use a hose to connect to the slave cylinder and bleed the fluid into a cup. so the slave cylinder sucks up brake fluid instead of air.
Old Aug 12, 2010 | 03:46 PM
i do use the tube and jar method normally, but i bought a hand vacuum bleeder a few days ago and have bleed it 2 or 3 times using that with no difference...
Old Aug 12, 2010 | 04:06 PM
Really? Damn, that sucks man. Then its not looking good for me either lol.
Did you contact SSP? What i told you is what they told me.
Old Aug 12, 2010 | 09:41 PM
Bighec's Avatar
What kind of fluid are you using?
Are you losing fluid?
How are your brakes, spongy?
Check all of your lines and make sure none of them are sweating.
All of your lines nice and snug?
Answer these questions, and someone might be able to point you in the right direction.
Old Sep 5, 2010 | 12:38 PM
--FIX
Yes Kris spent over and hour on the phone with me as we double checked all the possibilities.
In the end it was the master cylinder, i sent it back to them (free to me) and got it back totally rebuilt in about 2 days.
Has been working fine for over 800 miles now
Old Sep 5, 2010 | 01:29 PM
--FIX
Im having the same problem and have the same exact clutch/ssp mc2 as you too. Just shipped my mc2 to Kris also, so I'm glad to hear it was a quick fix and he got you back behind the wheel of your X.
BlowMeOff
Sep 28, 2012 11:55 AM
Psychedelic
Oct 26, 2011 11:39 AM
GTS08
Lancer Tranny/Drivetrain Tech
Feb 19, 2011 02:23 AM
maperformance
12
Feb 3, 2011 03:32 PM
wilbdog
13
Mar 23, 2010 12:05 PM
Quick Reply: Air magicly entering the clutch line?
