ETS o2/dp + ETS tp + T1R S76 cb - any thoughts?
Trying to pick components.
I love the ETS O2/Downpipe and test pipe design, but I'd like to pair it with a TR1 S76 cat back, as I heard the complete ETS turbo back is pretty loud.
I wish the testpipe had a resonator but I like the bend they engineered in to prevent rattling. Does the bend prevent a resonator?
Anyone running this combo?
thanks...
thanks...
Can you tell me what you are running? DP, TP, Cat back, any HFC or resonators etc?
EDIT:
Nevermind just realized you were the 200 cell V2 owner. How is the WOT in car? How many cats have you put in trees?
EDIT:
I'll put a plug in for my metal Ultimate Racing high flow cat. I might as well be running a test pipe. I had one HPDE inspection shop tell me that it'd never pass inspection. haha. It's a beast. Not SUPER loud, but respectable loud, but only a drone over 60 if you're in the rear. Front drone isn't a problem. But the flow is so awesome, I've been told its a perfect sound.
I'd make a GUESS that it'd fit, but might have "clearance" issues compared to those with bends. I have a bend in my HFC, and that seems common. The CBE would simply mount "higher" or "lower" (betting higher) and then you might end up with CBE issues rubbing on things like the drive shaft or gas tank heat shield. Which you might end up having anyway.
Ive got the ETS O2 dump, straight test pipe and perrin CBE and it sounds very nice cruising (not loud at all but a good grumble) and sounds like a raped ape when I open it up. Its a great combo in my eyes..... but the Perrin was also talked to be somewhat on the quiet end of the spectrum for noise levels.
HIGHLY suggest the ETS parts... they really are beautifully made
