AEM Boost Gauge
AEM Boost Gauge
I am thinking about getting AEM boost gauge to go along with my AEM wideband.
This is the gauge
$130 is not bad at all. Please share your experiences about this gauge.
Thanks
This is the gauge
Thanks
The only issue I've had is that occasionally the calibration is off by a few psi, sometimes +, sometimes -. Haven't quite figured out when the gauge actually calibrates. I have followed all suggestions for power with no effect. Doesn't happen very often so I've decided to live with it. Other than that, no issues at all.
Not keeping peak boost in memory is deal breaker for me anyways...
I think I amma go with the STRI DSD II 52mm
For my AEM gauges:
Fuse 3 - CONSTANT Power
Fuse 12 - IGNITION Power
If you get power from fuses 3 & 12 everything should work right every time. Most of the other IGN power sources cause problems with this gauge.
Here's what I did. I bought an HKS MT-6 turbo timer harness, so I can easily tap at the ignition source. From there, I ran a wire from the GREEN wire from the HKS MT-6 harness to a distribution block and then tapped my AEM boost gauge to the distribution block. Any future gauges you install, would just require you to tap at the distribution block, which makes it easy work. My AEM boost gauge flips between -18 to -20 on car idle, which is normal... I think.
Yeah mine goes between -18 to -20 at idle as well with AC off. Usually about -16 with AC on. Peaks around 20 to 21. Mine spikes up to 24 25 to in fourth at WOT around 4k rpm, but now i have the cobb AP tuned for the intake i have and no more spiking
For my AEM gauges:
Check out this thread: https://www.evolutionm.net/forums/ev...m-reading.html
1) I think the issue here could be the way people have their power sources tapped. If you start the car and then the gauge powers on and then, there's an interruption of the power source during the ignition start, it will force the gauge to re-calibrate itself before even finishing it's current calibration. I have my gauge set up, so that when the key is in the ON position, it sends power to the gauge and stays on, even while ignition start. The calibration process takes roughly 2-3 seconds to complete... although I could be wrong.
2) There's an erratic change in the vacuum line during calibration at startup.
The gauge performs it's calibration right away and set itself to 0, once it's powered on. There's two possible issues here:
Thanks for the info on the calibration. I do have a fairly long vacuum line to where I have the sensor mounted. Maybe I'll move the sensor so that it has a shorter run and see what happens...
RallySport Direct
Evo 'For Sale' Electronics / Lighting / Audio
30
Jul 25, 2017 08:26 AM
RallySport Direct
Mar 12, 2016 11:41 AM
RallySport Direct
EvoX 'For Sale' Suspension / Brakes / Handling
Dec 11, 2015 09:26 AM
RallySport Direct
EvoX 'For Sale' Exterior Styling
Dec 11, 2015 09:22 AM
RallySport Direct
Jul 31, 2015 08:51 AM
