2008 EvoX Starts, idles perfect for 3 seconds, then dies after installing rebuilt eng
Its got to be either a bad ground or a pinched wire. I was very careful about the wiring harness when uninstalling/reinstalling though so I'm really not sure. Hopefully I'll figure it out soon though. I put 30+ miles on the car tonight w/o the MAF plugged in! Drove like a champ, even in partial throttle boost (maybe 8psi or so?). Idles at 900rpm like it has no cams, even my wife approves! Hrm.....insta-speed density X
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Wahoo! Figured it out!!! I had put one thick, main ground just above the starter, when in fact it went below the starter. It was on the block, but the spot I put it on above the starter also held a small bracket (to hold the harness off the starter), and I had put the grounding wire on the outside of that--it must not conduct very well. I moved the ground to the correct spot (the manual actually has diagrammed where each one is), fired it up w/o maf to confirm it was working, then shut it off, plugged in maf, fired it up, voila!
Thank you everyone for all of the help!
mrfred
68
Jul 13, 2017 11:22 AM
evolancer04
Apr 27, 2011 12:58 PM
