Rear diff fluid change help.
Old Jan 8, 2011 | 08:20 PM
rcheung's Avatar
I just took at look at Russels DIY
https://www.evolutionm.net/forums/mi...rvice-how.html
For the Rear diff on page 00-79 It looks like there are two drain plugs and two fill plugs. One holds LSD gear oil and the other holds ATF SPIII fluid. It looks like just a drain and fill for the ATF SPIII fluid but I thought that had the be bled via the MUT tool. Is this drain and fill separate from the ATF SPIII resevoir in the trunk?
Old Jan 9, 2011 | 09:24 AM
rcheung's Avatar
ttt
Old Jan 9, 2011 | 09:48 AM
Kracka's Avatar
Yes. Both the rear differential gear oil and ATF fluids are simple drain/fill jobs.
Both drains use a 10mm hex bit. The gear oil (Diaqueen 90W LSD) fill bolt is on the front of the rear diff case and the ATF (Diamond ATF SP III) is on the rear of the case.
Old Jan 9, 2011 | 10:08 AM
jrlewis0550's Avatar
Has anyone used anything other than Diaqueen 90W LSD and had success. Im thinking of using an amsoil instead.
Old Jan 9, 2011 | 10:22 AM
Kracka's Avatar
People have used Redline, Mobil 1, Amsoil, etc. Everyone has their own opinions on the matter. Use which you like best, for me it's the straight 90W Diaqueen.
Old Jan 9, 2011 | 02:39 PM
Gqracer's Avatar
https://www.evolutionm.net/forums/ev...ld-change.html
here you go man..
Old Jun 23, 2011 | 01:24 PM
Evolved X's Avatar
Does any of that require "bleeding?"
Old Jun 23, 2011 | 01:32 PM
Kracka's Avatar
No, simple drain and fill.
Old Jun 23, 2011 | 01:44 PM
Evolved X's Avatar
Thank you! There are so many threads about this. This is the only thread that's consistent and I trust!
Old Jun 23, 2011 | 01:49 PM
Evolved X's Avatar
Also, for maintenance-wise purposes, change the transmission fluid (front transfer case), the gear oil, and the torque transfer mechanism part. That takes care of ALL the transmission fluids that need to be regularly changed (~30k mi or so) correct?
Old Jun 23, 2011 | 01:55 PM
Kracka's Avatar
-transmission
-transfer case
-rear diff mechanism
-rear diff tq transfer
These should all be done ever 15-30k miles depending on conditions.
Old Jun 23, 2011 | 02:05 PM
Evolved X's Avatar
-transmission
-transfer case
But since I have a GSR the transfer case is the transmission correct?
Old Jun 23, 2011 | 02:15 PM
Kracka's Avatar
Not unless you have a Subaru
The above list I made applies to all Evo X's: GSR, SE, & MR. In addition, the SE/MR also has a transmission filter to replace.
Old Jun 23, 2011 | 02:34 PM
Evolved X's Avatar
Is it too much of a trouble to ask to see the difference between the transmission and transfer case?
Old Jun 23, 2011 | 02:47 PM
ugakirk's Avatar
I don't really understand what you are saying. The tranny is close to the drivers front wheel. The t-case is next to that, on the "passenger side" of it..
