Turbo XS Bellmouth DP for evo x anyone have one?
So, I've been looking at this online, it looks similar to the ams wide mouth dp although no quite as well thought out, flowing, or astetic. However it can be found cheaper than the ams, which has peaked my interest. So, anyone one have one or done any testing with one? How does it stack up? It looks like the results would be close to the same gains by design, it looks like a poorly copied ams design. But still get cast and a bell mouth.
Here is what it looks like.
http://www.google.com/imgres?imgurl=...1t:429,r:5,s:0
It looks ok and would probably perform similarly...but unless there is a huge price difference might be worth it to just buy the real thing. Looks like it's on sale for $399 which isn't all that much cheaper than AMS' downpipe.
You can get MAP's for even cheaper yet too, I believe their retail price is $369. ETS has a nice one as well, but I think that one's closer to $500.
This is the only other one that I've seen that is cast. I have found cheaper options that are piping like the Rexspeed for about $210. The cheapest that I've found the ams is $430 and the best deal I've found on the turboxs cast peice is about $330, so $100 less. Options, options. I was going to get the perrin dp/cat combo until I read about the 25whp gains from removing the stock o2 housing on larger turbos, too large of a choke point, needs to be replaced.
Yep. Just read a post on this on evoxforum. AMS responded to the post and said that it looks like they copied the bellmouth portion and then went into piping to save money. I agree that the ams peice is nicer through and through, but is it worth it for another $100. Maybe to some, others no, I am still undecided, I'm pretty sure that the ams peice although nicer in construction will not make any significant gains over this peice. $330 is a much more reasonable price for a dp and this beign the only other cast option, it may very well be what I end up getting. Maybe I will be the first on the forum, if I get it I will let you all know how it works out.
Originally Posted by AMS
Here however is the real kicker and how I can say without a doubt this is a copied piece. The two threaded bosses on the head of the AMS widemouth downpipe were placed there for a heat sheild we were designing. They don't bolt up to anything other than what we are making here in house. I guess TurboXS was planing on copying that too. Again this is just from a quick glance... I am sure once I got to see one up close the differences would be even more apparent.
Eric Gaudi
Sales Manager
AMS Performance
Eric Gaudi
Sales Manager
AMS Performance
What are the advantages of a Bellmouth when compared to the stock design?
Would a twin dump pipe design (divorced wastegate downpipe) be better than the bellmouth?
The exhaust on my former car a Mazda3 MPS (230wkw or 313whp and 332ft lbs) was a divorced wastegate and made a lot more power than other cars with TBE intake tmic and tune. Around 15kw or 20hp more.
2. Depends who you ask, in my opinion yes divorced is better to help reduce turbulence by smoothly introducing the wastegaste gasses back into the exhaust gasses further downstream away from the turbo outlet.
Opinions will differ and people buy whichever they feel is better. AMS, TurboXS, and Megan choose to stick with the factory's bellmouth design while others such as MAP, ETS, and Ultimate Racing opted for the divorced wastegate design.
GarageLine.com
EvoX 'For Sale' Wheels / Tires
159
Nov 15, 2016 04:57 PM
GarageLine.com
Mar 8, 2016 08:03 AM
GarageLine.com
Evo 'For Sale' Suspension / Brakes / Handling
32
Mar 8, 2016 07:48 AM
itz_speld_rong
Sep 17, 2010 06:55 PM
