Ordered Garrett GTX3582R 450-750 hp turbo today!!
Old Jan 29, 2011, 01:19 PM
BLKCarbonEVO's Avatar
Interested to see how the GTX works out for you
Mikey
Old Jan 29, 2011, 04:37 PM
06MREvo's Avatar
Originally Posted by almostbuff
Just curious, did you have a bad experience with them? I believe they moved recently
No, but never really heard anything good about them. If I was having someone build and tune my car near Charlotte it would be Kasey. He is in the NC regional threads. Or I would take my car out to the Fayetteville area and have Force-Fed Performance and/or Spec-Ops Motorsports work on my car...
Old May 11, 2011, 11:16 PM
3grst01's Avatar
Any results / updates ? I am really torn trying to decide between gtx and fp black.
Old May 13, 2011, 08:42 AM
chkmgnt59's Avatar
if you already have supporting mods to make a black work, go black and enjoy. If you're starting from scratch, get a hta86, or gtx/hta82 if you want less power
Old May 13, 2011, 10:55 AM
Black Momba's Avatar
can not wait to see this thing in full effect good luck
Old May 13, 2011, 01:41 PM
almostbuff's Avatar
Not yet. I just received my Tial housing last week. It took forever to get here, and it's off to Calico for heat coating along with my ETS manifold and custom DP. I should have some numbers late next week
Old May 24, 2011, 11:27 PM
evolutme's Avatar
Any updates yet?
Old May 25, 2011, 01:18 AM
3grst01's Avatar
I have yet to see Dyno graph/ powerband gtx3582r results on 4g63/4 platform in high boost. Bump for results again the main reason I am so torn is if I go fp black / red I can always send it out to get ball bearing upgrade and even with journal bearing the results are readily available if you search. Hope this set up doesn't have too much lag. Good luck.
Old Jul 8, 2011, 10:59 PM
almostbuff's Avatar
I was really torn between this and the FP Black but in the end I decided to go with the new Garrett GTX line. As soon as I get some picks of my existing and new engine I will start a build thread. This will go on a built engine with Manley pistons, rods, springs, Cosworth bearings, Kelford stage2, etc on a 2.0 block. The rest is ETS: exhaust manifold w/ ext wastegate port, uicp, licp, 4" fmic, intake, recirc DP, HFC, & V2 Quiet. Fuel is provided via Walboro single 255 and I have a Bosch inline on the shelf.
This turbo will be replacing a Dom2 (for sale soon).
I have no intention of taking this thing anywhere close to the limit until I can get a new clutch/MC. Stay tuned....
http://www.turbobygarrett.com/turbob...R_803715_1.htm
Slowly but surely. I should be up and running Monday.
Attached Thumbnails Ordered Garrett GTX3582R 450-750 hp turbo today!!-2011-0-3.jpg   Ordered Garrett GTX3582R 450-750 hp turbo today!!-2011-0-4.jpg   Ordered Garrett GTX3582R 450-750 hp turbo today!!-2011-0-2.jpg   Ordered Garrett GTX3582R 450-750 hp turbo today!!-2011-0-1.jpg
Old Jul 9, 2011, 07:38 AM
racerx43269's Avatar
good luck... that is the route im going... I think ball bearing is much better then journal bearing ( fp black is journal )
Old Jul 24, 2011, 03:07 PM
4G63 T's Avatar
update please
Old Aug 3, 2011, 06:52 PM
ayoitzmayo's Avatar
cant wait to see how it turns out good luck
Old Aug 3, 2011, 07:17 PM
almostbuff's Avatar
more stuff
changed to 08 aluminum valve cover & ETS had to do a custom intake for me which should be here tomorrow.
Attached Thumbnails Ordered Garrett GTX3582R 450-750 hp turbo today!!-aluminum_valve_cover.jpg
Old Aug 4, 2011, 04:44 AM
JDMCT9MR's Avatar
Can't wait to see the results!
Old Aug 6, 2011, 07:56 PM
almostbuff's Avatar
Engine in car...
Car was started Friday. No leaks, oil pressure is good. The charge pipe has to be finished and a small section of the downpipe.
Attached Thumbnails Ordered Garrett GTX3582R 450-750 hp turbo today!!-engine_started1.jpg   Ordered Garrett GTX3582R 450-750 hp turbo today!!-engine_started2.jpg   Ordered Garrett GTX3582R 450-750 hp turbo today!!-engine_started3.jpg
Quick Reply: Ordered Garrett GTX3582R 450-750 hp turbo today!!
