ATTN all X owners: factory transfer case fluid
Old Mar 9, 2011, 09:09 AM
Hiboost's Avatar
So it is likely a wise idea to also check the Rear Differential, if they overfilled one they could possibly overfill the other given that they use the same fluid. Then while you are at it verify that the Transmission isn't overfilled as well.
If you are past 5k miles you may as well swap the fluids for Redline or Amsoil synthetics as an extra measure of protection.
Old Mar 9, 2011, 06:41 PM
crashway2many's Avatar
This happened to me. At 20k a seal blew out in my transfer case. I had to have the whole transfer case replaced. They said the cause was that it was over filled.
Old Mar 9, 2011, 07:05 PM
steven88's Avatar
was it under warranty?
Old Mar 9, 2011, 07:40 PM
Yea but it took FOR EVER!!! I had to turn the car totally stock. It took a month for them just to approve the warranty work.
Old Mar 9, 2011, 07:51 PM
I dont think the transfer case was totally shot. A bearing went bad in the tc, due to the lack of fluid. For what ever reason they don't or cant service them. They just replace the whole thing. Good if warranty is paying for it. But if you have to pay out of pocket i think Shepard trasmission can rebuild it for a lot less.
Old Mar 10, 2011, 01:01 AM
steven88's Avatar
that freakin sucks...damn it's making me think about taking the TC fluid change to the dealership instead of doing it myself...just because i've heard of so many issues with the 2010's
damn
Old Mar 10, 2011, 01:03 PM
Kracka's Avatar
No problem with doing it yourself, as long as it's not making abnormal noises then you'll probably be fine even if it is over-filled. If it is making abnormal noise already then let the dealership handle is so they can document the factory paint seal still being intact to prove it was the factory who over-filled it.
Old Mar 10, 2011, 01:25 PM
goodhart's Avatar
This needs to be a sticky IMO.
(Here, style and evomn really)
Old Mar 10, 2011, 01:30 PM
Kracka's Avatar
Added here: https://www.evolutionm.net/forums/ev...ssues-etc.html
Old Mar 10, 2011, 05:25 PM
EvoX-11's Avatar
can someone post a picture for the drain plug? I have no idea where it is located
Old Mar 11, 2011, 12:06 AM
steven88's Avatar
thanks for the info...is there a particular noise i should be looking for? and under what conditions?
Old Mar 12, 2011, 06:40 PM
comic0guy's Avatar
^ yea, I'd also like to know what you might hear or sense if its starting to have a problem
Old Mar 12, 2011, 08:58 PM
Kracka's Avatar
A howling or whining noise that increases with speed.
Old Mar 12, 2011, 11:14 PM
chazyronnie's Avatar
Good to hear about this, does the Ralliart have this issue too???
Old Mar 13, 2011, 02:13 PM
Kracka's Avatar
No idea.
Quick Reply: ATTN all X owners: factory transfer case fluid
