ATTN all X owners: factory transfer case fluid
#92
I wouldn't worry much about the exact torque.. just don't be an asshat and over-tighten/strip it when you tighten it on there.. and to cover the other half.. make sure it is on tight enough to not come off
#94
Is this fool proof to check? I don't have any way to get under my car and it be level so I will have to have a shop do it for me. But I just hope they don't mess it up. It looks as though from the illustration on the preceding page that as long as they take out the right bolt there will be no way to drain it too much. As long as the car is level and the right bolt is taken out I should be good, yeah?
#95
if you are doing a check, then just pull the "fill" plug out...if no fluid comes out, you are fine...plug it back in and be on your way...if fluid comes out, wait till everything comes, then plug it back in
if you are at 15k, you should look into getting the fluid changed...might as well since its going on the rack
#96
ahh ok, thx.
#98
A little late to the party, but just checked my '10 SE at 1400 miles, and it was bang on.
Just adding it to the different variety of years/model data in this thread if anyone is keeping track.
OT: also had my alignment checked. Front was accurate, LR toe was out by about .08"
#99
I had a leak at 35k miles on an 08 on my TC.
Dealer took many visits to isolate the issue - idiots. TC was probably damaged over time due to this.
Finally they Resealed output shaft seal at 41k miles. Later still leaked. Probably was never reassembled 100%.
At 43k whine of death started. I Confirmed with acoustic analysis was TC at a race shop. Sounded very bad.
Went to a recommended dealer with best Evo tech in town. Took him one hour, got call back, new TC on it's way for replacement next week. The TC was completely dead, internal magnets were shattered.
Amazing there are so many issues with these TC's.
I'm assuming the level will perfect this time around.
#101
Just took my car in this morning to have this looked at. Didn't even bother checking the fluid level, seems like the damage is already done.
#104
My dealership claimed the oil in my driveway was from the oil pan plug leaking, that got replaced. This particular problem was not addressed as Mitsu won't do anything about it because it's 'seepage' and not a full 'leak'. So far no more oil stains in my driveway, but I'm going to wait another few days to see if the 'seepage' gets any worse.
