Evo X Final Drive 4.28
Drag ? I am beyond curious about this final drive....I've contacted shep and he gave me the gearing specs based on the stock wheel/tire size and 8k rev limit on the evo x..but I am just curious if 500whp area on a FP black with cams would be good for the final drive in the 1/4mile...
Well if you look at the image that was just posted it shows the differences at each speed in 5th:
70 mph = 3300 vs 3000
80 mph = 3750 vs 3350
Since all gears are spaced the same, it leaves you at the same RPM you were at before, just the whole tranny is more overdriven. There is also an option to get a shorter 5th gear so that you don't drop down as far to 5200 after shifting 4th to 5th. Not really sure how much of a difference that 300 RPM will really make but who knows. Hopefully that doesn't make 5th rev higher than stock rpm's or highway driving would be a nightmare.
Everyone is a little different, so your end goals are what you need to consider. I have the taller final drive. If you're just looking for 500whp territory just rev the car(built motor) and ride out 4th in the quarter... That is if you want to have good times in e quarter. I don't launch my car but I would like for it to be capable if I took it to the strip once or twice(so my setup isn't ideal for drag). I really do enjoy the tall gearing just driving around town which is what I mainly do.
sooo , any ideas , for an evo x with fp black , cams , boltons and 500 hp would the final drive be useful?? since really the stock gearings are short?!
i dont think the car would fall out off power with each gear shift since the fpblack spools quick
yeah i guess ur right! , after a terribly long time thinking about this, i reached the same conclusion as u did.
sniperX2014
Jun 19, 2018 10:18 AM
Bear.914
22
Mar 1, 2010 04:21 PM
06GraphiteEvoIX
14
Feb 21, 2010 01:24 PM
