valve lash gap?
valve lash gap?
Anyone know the standard valve lash gap for evo xs? Tried searching but the only specs I can find are for earlier generations. Trying to adjust my valve lash but can't find the specs anywhere!!
thx for any info
thx for any info
The service manual says 0.20 and 0.30 mm for valve clearance but is this value changed with aftermarket cams?
Kelford instrcts us to use 0.30 and 0.35 mm for valve clearance with its 214 series cams at http://www.camshaftshop.com/home?pag...category_id=91
which values should be used with aftermarket cams?
Tw3NTy0n3
May 21, 2016 11:24 PM
10, 2008, adjustment, aftermarket, cams, clearance, evo, evolution, gap, important, lancer, lash, mitsubishi, spec, valve
