Exedy Twin Disc or ACT HD 6 Pad?
Im up in the air on what clutch I want. If anyone has experience with either one or both, and can tell me what they thought of them.
I heard a lot of good things about the Exedy Twin Disc. Havent heard much about the ACT HD 6 Pad. I heard the ACT HD 6 Pad can hold as much power as the Exedy Twin Disc but it cheaper. What are everyone elses thoughts?
The car is my DD and will see soon track time. Im just under 400whp right now and plan on getting between 450 and 500whp soon.
If you launch your car get the ACT.
The ACT 6 puck will hold more torque and take more abuse than the exedy twin...but will be tougher to drive. I am used to mine and it doesn't bother me at all, I think its pretty easy to drive and it doesn't chatter really at all.
The exedy twin will drive like stock basically and hold quite a bit of torque, but you will burn through it launching. We have seen many examples locally of the ACT holding up much better to higher torque and launching. But again it doesn't drive as easy.
If you care about stop and go traffic (The ACT isn't too bad in traffic imo)and want a really easy clutch then get the twin....as long as you don't mind the big price tag.
Also, you will want to upgrade the MC for sure with the exedy twin...however the ACT 6 puck we have quite a few people locally still running the stock MC..so you save there too.
Honestly, unless you really care about a smooth clutch get the 6 puck.
I run the 6 puck w/ streetlite fly wheel. i am still on stock CMC, however i have a magnus on in garage for just in case. The act 6 puck is more like an on/off switch. either you are engaged or not... different to get used to the new engagement, especially from a dead stop. i love mine. good luck on your venture.
And see I feel completly different. I would rather have a twin disk that a 6 puck clutch. To me the pedal pressure is so much nicer for driving than a 6 puck. I find it hard to understand how someone could say that with a 6 puck you do not have to worry about upgrading a CMC.
One of my biggest reasons to go with a twin disk is how it saves my transmission. Yes you pay a little more for a twin disk up front but you end up paying less down the road in my experiences. I could not get my last car to shift over about 7800 when using a 6 puck. With the twin disk it was completly smooth shifting around 8.8-9k which was where I was shifting at. Granted you probably don't daily drive shift that hight but your 1-2 shifts can be in excess of 7.8k
This is just my experience as others may have different experiences. In the end you just have to weigh the pro/cons of each and decide which one is more suited for your use.
I shift at 9k all the time...zero issues with my 6puck.
I have launched it a few times. seems to be easier. Magnus from what i have seen uses the IX cmc with their adapter.
droppinbottom....not a matter of not worrying about not replacing the CMC, i worry about it when i launch. every owner of an aftermarket clutch worries about it. those that have certain clutches KNOW they will be replacing theirs. others it is possible, mostly based on how you drive. i have 9k miles on my 6 puck and have had zero issues with my stock cmc, but that dont mean that someone with a new 6 puck ACT won't blow theirs out in the first month or so.
My ACT 6 puck was toast at 40k miles, but what was most scary was that even though it held the power, it was down to the rivets and about to self destruct. There was a crack through the clutch disc but the flywheel and pressure plate looked perfectly fine.
All I can say is that I'm glad I had an Exedy HD twin installed before disaster struck. I had threespeed send me one of their new stainless steel scattershields for testing and we are just making tweaks for final production. The thing fits like a glove and if disaster strikes you won't send shrapnel through your entire engine bay.
subrwho
23
Jun 25, 2010 03:38 AM
