Word of Warning: Inner CV Boot Leaks
Old Apr 25, 2011, 04:34 AM
AWDTerror's Avatar
Originally Posted by macPSU
Exactly what mine looked like.
The problem is that green clamp, the way they are designed they get loose over time due to centrifugal force. If you go with a one-ear type they will last much longer and you have the ability to re-tighten them using a set of pliers.
Old Apr 25, 2011, 06:41 AM
lapoune's Avatar
This is in the maintenance schedule BTW...every 5k
Old Apr 25, 2011, 07:00 AM
AWDTerror's Avatar
Just to check, not to replace.
Old Apr 25, 2011, 01:49 PM
lapoune's Avatar
yeah...I wonder what the dealers do when they see the leaks..if they even bother to check
Old Apr 25, 2011, 03:24 PM
AWDTerror's Avatar
prepare to *** rape you...with no lube.
Old Apr 25, 2011, 07:08 PM
EndlessRed's Avatar
no reach-around?
Old Apr 25, 2011, 07:14 PM
AWDTerror's Avatar
Originally Posted by endGameXIII
no reach-around?
Mitsubishi will make you give yourself the reach around.
Old Apr 27, 2011, 05:56 PM
teethandnails's Avatar
Get some Gorilla axles
Old May 13, 2011, 11:56 PM
Porkskins's Avatar
Dealer repacked inner cv joints and replaced the boots up front under warranty which was suprising. They did not replace the rear leaky boots because "they werent slinging grease everywhere like the fronts", although you can see greasy spots on the subframe.
Waiting on a backordered cd player replacement to come in and they will take pics of the rear boots and send them to the higher ups to see if they can be replaced under warranty...
Old May 14, 2011, 12:23 AM
MR. EVO MR's Avatar
What better clamps should we get?
Bump
Old Feb 20, 2012, 02:06 PM
black rat's Avatar
Again what clamps and where can we get this?
Old Feb 21, 2012, 06:14 AM
IceCold98GSX's Avatar
I already had to replace one axle. I have two others that are seeping by the green clamps. These are the same kind I bought. Obviously the smaller ones though for the inner boot.
http://www.autozone.com/autozone/acc...er=964590_0_0_
Old Feb 22, 2012, 05:11 PM
black rat's Avatar
did you regrease the joints or just replaced the clamp?
if so what kind of grease did you use?
Old Feb 24, 2012, 09:34 AM
AWDTerror's Avatar
I just used whatever the service manual called for grease.
Old Feb 24, 2012, 10:34 AM
Red Dragon's Avatar
Some one should make a "How To".
Quick Reply: Word of Warning: Inner CV Boot Leaks
