Diff pins failing symptoms
I just want to put together a thread that lists all the symptoms of your diff pins failing. This way people can possibly diagnose the problem before it becomes a huge problem, like me.
So, if you know of any symptoms of diff pin failure or failing, post them up, and I can update this first post if you suggest so.
I notice a rattling metal sound if I'm slowing down and am in too low of a gear (3rd @ say 15mph) or if I'm accelerating sloooowly and going through the gears...the sound seems to be heard coming from the rear. AM I IN TROUBLE?!?!
I have a fairly quiet rattle (but you can hear it) when I lift and coast in gear at 3K rpm or so. Doesn't happen at lower rpms and goes away completely if pressing the gas a little or the clutch. I'm pretty sure its always done that, but I'm admittedly a little paranoid since I just took the car out after the winter and installed several new parts so I'm listening to every noise. To give an idea - you can't hear it with the heater fan on.
Im going on my 3rd tranny due to the diff pin failure....the only time I knew there was an issue is seeing a puddle of oil under the car....I never noticed any noises,grinds,popouts, etc...but this time im playing it smart and purchased and tranny and sent it out to shep to get a full rebuild plus diff pin mod
evoscan
52
Jun 20, 2017 01:46 AM
EVO8LTW
Nov 1, 2009 08:36 AM
