Well my clutch is done.. replacements?
It slipped REALLY bad in a 2nd gear pull tonight. I need to replace it with a clutch that isn't going to explode my CMC. What clutch are you guys running with the stock CMC. I heard exedy breaks it most of the time. Act w/ performancestreet disc?
I'm not really going for crazy high power. It's my DD and I want something very streetable.
i have ACT 6 puck with streetlite fly wheel. i am still on stock CMC with 10k miles. I am hard on my car at times. But this clutch is more of an on / off switch. maybe street disk would be better for you. of your on a budget, turn your fly wheel or get a MAP flywheel. they are rebuildable. Whatever your decision on clutch, give MAP a call and ask for Adam. they are the cheapest, best customer service alot of us have had. really good guys there.
it will be cheaper to turn it. knowing what i know now about the process. i would have turned mine than got street lite fly wheel. the amount that gets shaved off is about equal to the weight of the street lite. save alot of money. evodave did a write up on this same thing. it is where i got the info from and decided to do it. but cant for life of me find the link to it.
Ha, I've been in your exact position the last couple weeks. I was bouncing back and forth between the Stage 2 Exedy and the ACT HD SS (and a couple others). I decided that there were too many comments on here about the chatter of the Stage 2 (it's basically a 3 puck = chatter). Since my Evo is my DD, I didn't really want to worry about spending the $$ on a new clutch then hear it EVERYDAY and wish I had made a diff decision. No one is in my area that runs the Stage 2 so I wasn't able to actually HEAR how badly it chatters; an option that may be available to you.
As far as your flywheel, I decided that even though it's cheaper to machine the flywheel and people on here say it works fine afterwards, as long as everything was already open, I might as well go ahead and replace my flywheel. This also should make the down time of your vehicle shorter (if you're worried about that) since they won't have to send out your flywheel to get it milled. I've got the MAP fly coming.
Once you've made your decision on parts, contact Adam over at MAPerformance. They have SWEET deals and EXCELLENT customer service. You'll be happy to do business with 'em!
Also, search for a thread on "Center Diff Pins". Since the shop will already have the motor half torn down to get the clutch out, might as well get in there and replace those while you're at it. Shep and Baschur make pin kits. I don't know the difference and most people here don't either. Once you start researching those options, you'll start to wonder yourself. I have the Shep ones coming for various reasons.
i am using this. its a good clutch for a price and does not chatter at all.:
But the best is the Exedy Twin which is chatters = awesome.
anyway i am using this right now.:
http://www.amsperformance.com/cart/E...lutch-Kit.html
i will go for the Twin HD , since they bump me up in category, and now i can have more plates by the rule
I don't understand your comment. Are you saying that the chatter is awesome or that the Twin is awesome? If it's the second, I completely agree and if I had $1700+ for just parts or if I was going crazy with the power, I would have gone that way. But neither applies for me.
In motorsport you got what you pay for. Sooner or later every one will discover that. i am on my second sets of Exedy stage 2 with 13 K miles. But i am driving it hard though.
