SST Downshift problem...
What happens is, for example, when im doing 40km/h in 4th gear and I brake and go down to 20km/h the gear gets stuck in 4th gear and takes 3 to 5 seconds to actually shift down to 2nd gear. I keep pressing the accelerator but nothing happens till it downshifts to the right gear. Not that it only happens btw 4th and 2nd. Sometimes it also happens in different gears. It doesn't always happen but whats scaring me is that it is becoming more frequent than it used to be. Basically the car gets stuck in a particular gear and sometimes it takes a lot more than the usual time to downshift and start accelerating again. I barely drive in Sport mode so i've only faced this in Normal mode. Does this happen to all the SST cars or am I facing a problem ???
I've had the same issue. Happens occasionally when manually downshifting. I've only experienced it in normal and I drive in sport prob 10%. From what I remember, it's more of an issue when you downshift while the car is in auto.
Registered User
In normal mode, the car is trying to stay out the band to spool up. I think it will take the turn on a higher gear lets say the 4th gear then when you press the gas it will downshift to whatever gear (2-3) and go. This is not sport mode where it downshifts fast to pick your gear and then jets you out.
90% of the time I drive in normal mode and in D and that is when its happening. Only rarely do I put it in sports and use the paddle shift so don't really know if the problem is there in sports mode. Even in normal D it doesn't always happen. Maybe two or three times everyday.
RalliartMY10
Apr 28, 2024 10:30 AM
sirchumpalot
27
Nov 28, 2012 12:07 PM
richardjh
Mitsubishi TC-SST Discussion
10
Dec 22, 2010 06:45 PM
