DTC Code P183D
DTC Code P183D
has anyone faced this dtc code here yet? =S whenever awc service required warning is on, going into gear 2 on Normal D mode, will have clunking sound, exactly like when i started the engine.
Tried scanning using Torque, with OBD2 Port connected to ECU, it detected P183D - Drivetrain. not sure if its even accurate..but sometimes when AWC service required is on, going from Gear 2 always has that sound.
Went to Mitsu dealer to do diagnostic, they detected ABS Pump Low Voltage..C2116 ?
whats the problem here guys? ABS and ASC Off lights are also on at the moment.. replaced the rear right ABS, which was faulty. but the lights are still there.. If i did warmup like 10mins or more, sometimes the ABS and ASC off lights will go off for like about 30mins to 1hour..sometimes less..
need help!!
need help!!
overdrive1
Jul 13, 2024 09:45 AM
ivan308
Jun 6, 2017 06:01 AM
skyseer
Nov 9, 2010 07:34 AM
BadazzCR
Aug 23, 2008 07:40 AM
