Boost Solenoid Explanation
Ok, I am fairly competent when it comes to these things, but could someone give me the quick and dirty on the boost solenoid? Looking at the way its plumbed, there is a pressure line going straight to the wastegate...why would it also need to go into this solenoid setup and then back to the intake??
Please enlighten me!
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
Essentially it bleeds the pressure coming from the intake to delay the wastegate spring from actuating the wastegate. Say the spring will compress at 10psi opening the wastegate, the solenoid delays that from happening by bleeding some of the boost. This is what happens when you "raise" your boost.
WTB[SouthEast]: OEM Boost solenoid pigtail harness
Igaly1021
Jan 13, 2017 01:15 PM
metallics2000
Oct 8, 2016 10:47 PM
