ETS Downpipe or Cobb Downpipe ?
Help me out here guys.
Ets downpipe or Cobb downpipe which one should i get. Both products are good but the cobb is almost half the price is it because the Ets has a flex flange or is it just a better product
Not sure which ETS one you were looking at but they have the recirc and dump O2 eliminator pipes so this is where the added cost is.
See here
http://www.extremeturbosystems.com/E...-Downpipe.html
as apposed to here
http://www.hopupracing.com/grairdiplma6.html
See here
as apposed to here
Cobb downpipe of course;
Below are some sound measurements we took within the SAE guidelines.
Stock Exhaust
idle - 74dB
SAE - 81dB
Stock DP & Cat with COBB Cat Back
idle - 80dB
SAE J1169 - 88dB
COBB DP, Stock Cat, COBB Cat Back
idle - 79dB
SAE - 93dB
COBB DP, COBB Catless Test Pipe, COBB Cat Back
idle - 83dB
SAE - 98dB
COBB DP, COBB high flow Catted Test Pipe, COBB Cat back
idle 80dB
SAE 94dB
Stock Exhaust
idle - 74dB
SAE - 81dB
idle - 80dB
SAE J1169 - 88dB
idle - 79dB
SAE - 93dB
idle - 83dB
SAE - 98dB
idle 80dB
SAE 94dB
Also, the COBB piece does not replace the section that connects to the turbo. From what I have heard, you only want to do that one time because it is a PITA to get to.
