Throttle body problem?
I have evo x and I was under full throttle in 2nd gear and suddenly I lost the power. I thought I hit the rev limiter but no I was around 6k rpms. After that it seems the car is really sluggish and the turbo will turn only if I depress the gas pedal all the way, before it was much sooner. Next day the throttle worked fine and the turbo was engaging around 3k rpm as it was supposed to. I went to a mechanic and he found two codes: p-0123 and p-1233 both connected with the throttle body
Is this something that showed up as I was pushing it that day or I will have a problem with this?
FS[Northeast]: Evo 8/9 oem throttle body W/O Sensors
yellowevo82
10
Mar 17, 2017 06:42 PM
musca999
May 10, 2006 09:17 PM
